Get your Forestry Forum Hats while they last!
As Randy88 pointed out, two saws is great to have when working in the woods. you can cut one saw out if the bar gets pinched and you can't free it. If two saws is not in the cards for you right now, a spare bar and chain is the next best thing. If you get stuck, just remove the powerhead fro the stuck bar and chain, put in your spare, and cut the first out.John Mc
Pinching a bar is not exactly a freak thing, and happens to the best pros and the beginners alike. Being as your still pretty new Im sure you will get a taste of it sooner than later. Having 2 saws or a spare bar/chain is a good idea, as well as a few wedges. These can get you out of a jam pretty well. The info already given here is a very good starting point, these guys have ya on the right track.
Quote from: JohnG28 on September 09, 2010, 02:22:43 pmPinching a bar is not exactly a freak thing, and happens to the best pros and the beginners alike. Being as your still pretty new Im sure you will get a taste of it sooner than later. Having 2 saws or a spare bar/chain is a good idea, as well as a few wedges. These can get you out of a jam pretty well. The info already given here is a very good starting point, these guys have ya on the right track.Well, when I go out I generally bring my current saw. Two weges and a maul.
As for pinching I've got one of my sons ... who's never pinched his ever
I am for the most part cutting poplar and white pine. The pine is quite big 20" or so.. The poplar is slightly smaller. Not much hard wood that I can get too. A lot of nice maple but it's to much for my old Fergusson. For now.
Quote from: ArcFault on September 04, 2010, 12:41:56 amI am for the most part cutting poplar and white pine. The pine is quite big 20" or so.. The poplar is slightly smaller. Not much hard wood that I can get too. A lot of nice maple but it's to much for my old Fergusson. For now.Arc, there's a lot you can do with your old tractor that you may not be aware of. If it runs worth beans you should be able to pull out maple trees. My dad's '48 John Deere B would pull out two 16" maples tree length together at the same time. If the tree is too big, cut it into logs you can handle. Even a quite large diameter tree you should be able to pull in short pieces, 8-12 feet long, or whatever. If your Massey's running right, you should be able to do it, if you have good tires. If not, you might consider getting some chains for it, if you can find some used (on internet, or whatever) or they'll cost less than new tires and you'll be able to bite in. Make sure your individual rear wheel brakes work, too, as you can use them to help control rear wheel slippage, especially in situations where one wheel gets on ice but not the other one, etc. Use your 3-point hitch to lift the front end of the log off the ground A LITTLE. This will put your traction on the rear wheels and also help keep the front of the log from snagging on stumps and stuff. [For smaller, lighter logs, it is ok to lift them higher off the ground, 2 or 3 feet if they're not very heavy for the tractor]. Go slowly when you have a big log on like that, no faster than about 2 mph (3 k) unless you know you are on a smooth skid trail where you are not going to hit any bumps or stumps. If the front of your log hits a stump dead on it will most likely cause the tractor's front end to lift off the ground-- sometimes lightning fast. When skidding large logs you must drive with your foot hovering on top of the clutch pedal ready to plunge it in instantly if the front end comes up. Also, drive very carefully through terrain where there may be stumps, rocks and other obstructions, avoiding hitting them with the end of the log. If you are traveling on a known skid road where you know there are no obstructions, you can feel free to go faster depending on the terrain, the load, and the condition of the tractor. Just know those old beasts can upend themselves in a hurry and if you don't have a roll-bar and seat belt you could be crushed instantly. Use common sense. Don't ever stop thinking about what's happening, and think safely. Don't drive a tractor or operate a chainsaw when you are angry or really preoccupied or upset about something. Take time to calm down and let it pass. Some time I'll share my full aspen pinch story with you. Never lose track of what's going on.I wish you good fortune with your enterprise, buddy! Keep us posted as to how you do.Jim
I am for the most part cutting poplar and white pine. The pine is quite big 20" or so.. The poplar is slightly smaller. Not much hard wood that I can get too. A lot of nice maple but it's to much for my old Fergusson. For now.Just curious, is the pine that you are cutting for firewood? I recall that you said in another post that you are helping out your girlfriend's family with maintaining a firewood supply. I realize that you said the hardwoods are more difficult to get to, however the hardwoods are what you would be looking for if your cutting for firewood. I know that pine can be used as firewood, but it is not a very desirable wood to burn. Just a thought.
Quote from: ArcFault on September 04, 2010, 12:41:56 amI am for the most part cutting poplar and white pine. The pine is quite big 20" or so.. The poplar is slightly smaller. Not much hard wood that I can get too. A lot of nice maple but it's to much for my old Fergusson. For now.Just curious, is the pine that you are cutting for firewood? I recall that you said in another post that you are helping out your girlfriend's family with maintaining a firewood supply. I realize that you said the hardwoods are more difficult to get to, however the hardwoods are what you would be looking for if your cutting for firewood. I know that pine can be used as firewood, but it is not a very desirable wood to burn. Just a thought. I know, all I can get to is poplar and pine. LOTS of poplar. So I just rediulous amounts of it. They go through a lot of wood here. At the far back corner and just on the other side of the marsh is where all the maple is. I can't get to it. I tried pulling it through the swamp. Lost it. It sank. I also tried putting it on a little slay type thing while pulling it across the swamp. I still lose it.What type of wood is burch? I can see a bit of a hill and it looks like there may be some yellow and a decent number of white on it.
