Get your Forestry Forum Hats while they last!
bring that modded 441 on over here i got a modded 460 looking for lunch......it hasnt found a husky or dolmar it dont like to eat either. and yep its used every day.
I work next to a tool and die shop, and they made me titanium internals (rings, piston and wrist-pin) tweaked the carb, (still waiting for them to make a bigger intellicarb.) put it all back together with no gask to raise compression to 175psi.
Randy-J Step put of the stone age ....the metal the piston was cut out of is called TiTu, it's a titanium tungsten moly, I didn't call it that because i thought i would lose people but it looks like dumbing it down to plain ol' titanium was too much for you.....research your "knowledge" before you start getting jealous again ......man, you 460 owners really are bent about the 441 aren't you? If you want to apologize, i will explain to you what the advantages are of the TiTu moly...but only if you say please
Quote from: 441FELLER on August 16, 2010, 08:35:04 pmMr.Al_smith, Step put of the stone age ....the metal the piston was cut out of is called TiTu, it's a titanium tungsten moly, I didn't call it that because i thought i would lose people but it looks like dumbing it down to plain ol' titanium was too much for you.....research your "knowledge" before you start getting jealous again ......man, you 460 owners really are bent about the 441 aren't you? If you want to apologize, i will explain to you what the advantages are of the TiTu moly...but only if you say please You might want to work on your reading comprehension there, Sparky. Maybe double check who posted what.
Only has about 200 psi compression static
QuoteOnly has about 200 psi compression static Do you use a jet fuel mix with that high of comp? 113?
