Get your Forestry Forum Hats while they last!
I've seen a couple of guys who give me nightmares with their drop starting technique. One guy is just flailing all over the place, with the saw swinging in various directions. No two starts look the same. He claims to have the saw "in control" -- but has nicked his chaps on at least one occasion that I've seen, and taken a chunk out of the visor on his helmet on another. Both happened when starting a saw. You'd think this would be a warning to him that his technique needs a little adjustment. The only thing he leaned from this is that "It's a good thing I always wear my safety gear". I can't argue with that... it's a DanG good thing he wears it. But he's still a good candidate for the Darwin Award for chainsaw starting.
The other method I see a lot of (which is totally idiotic in my opinion) is holding the saw with the right hand by the rear handle and thrusting the saw forward while pulling the starter handle with the left hand. This results in the saw firing off while there is absolutely no control over it, the tip of the bar is very likely to contact the ground, and if the operator holds it up then the spinning chain will swing back towards the operator's leg. This is the most common method used in these parts and it drives me crazy watching these idiots try to start a saw.
That felow in the youtube video is doing it backwards. The saw can start and go right into his leg. He should have it turned around the other way and switch positions with his hands.
