Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Mechanical Advantage  (Read 1369 times)
Offline Kevin
    • The Milling Masters
« on: November 05, 2003, 04:42:17 pm »
No, not tractors or skidders.
Mechanical advantage using blocks and pulleys.
I don't see this mentioned often and it is handy for winch loading a trailer which so many small operators do here.
I loaded a couple of 12' spruce logs today about 14"dia using pulleys and pulling the rope by hand hauling the logs up a ramp and onto my trailer.
The third was over 20"dia. and required the rope winch but it was easily loaded.
Save your back and try a mechanical advantage.
http://www.btinternet.com/~fourthgill.seascouts/tackle.htm#Luff_Luff
Offline Chet
Re: Mechanical Advantage
« Reply #1 on: November 05, 2003, 08:13:55 pm »
Da last logs I loaded on my trailer using ramps I used a rope too. But I used a lot of mechanical advantage, I used my pickup.   ;D
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline DanG
« Reply #2 on: November 05, 2003, 08:57:14 pm »
Yup, mechanical is definitely an advantage. :) It beats manual, any day. It even beats Manuel on a hot day.
Seriously though, you are right, but if I have a trailer, that means I have my truck, which has a winch, which don't require me to pull on a rope. I do have some blocks and ropes, though, and won't hesitate to use them if I need to.
Offline Bro. Noble
« Reply #3 on: November 05, 2003, 09:00:59 pm »
And don't forget levers.   I find the levers on our front end loader especially useful :D
Offline Kevin
« Reply #4 on: November 06, 2003, 08:04:25 am »
I give up!
:D
Offline Woodhog
« Reply #5 on: November 06, 2003, 03:31:51 pm »
I was thinking of this the other day when I had a big spruce
hung up (first one for 30 years) .      :)
I was thinking of getting a block and using it for a movable
pulley. i.e. making one end of the winch cable fast to a tree,
hooking the block to the butt of the tree, then the free end
would come back to the winch drum, I think this about doubles the pull on the tree??, however if that is so does it
also mean the cable could break by its normal breaking load being exceeded...???      OUCH!!!!    :(
Offline Kevin
« Reply #6 on: November 06, 2003, 04:45:17 pm »
The force on each winch line would equal the load, the force on the anchor would double.
I would opt for two blocks for a better MA as in fig 9 Luff.
Offline Ed_K
« Reply #7 on: November 06, 2003, 06:07:39 pm »
 When I get a hangup, the frist thing I try is to run the cable around the butt a turn and a half to two turns, and try to screw the tree around enough to break the top free. also try using a slid or two to get the butt off the ground and foward in one motion.
Ed
Ed K
Offline Kevin
« Reply #8 on: November 07, 2003, 01:13:37 pm »
Good idea Ed, here's a good example of MA from How Stuff Works...
http://static.howstuffworks.com/gif/bt4.gif
Offline Don P
    • Calculator Index
« Reply #9 on: November 08, 2003, 05:56:45 pm »
The ridge here was lifted on the line of pump jacks that are here shown lowered to be the working scaffold under the ridge. The back rafters over the loft floor were hand set first. Then the clamp on gin pole was hung on them and a suspended block and tackle lifted the front rafter. This was all pretty heavy cypress. Michelle handled the haul line.
Offline D._Frederick
« Reply #10 on: November 10, 2003, 04:39:01 pm »
Woodhog,
Your post #5, you are correct that your pulley system will double the pulling force to the tree. The tension on the cable will be no more than your winch will pull.
Offline woodmills1
  • the truth shall set you free
« Reply #11 on: November 11, 2003, 06:20:43 pm »
Now mentioned twice the theoretical value of tension in the cable would remain constant.  But, I fear the friction introduced into the system would in fact increase tension in the cable.  Now if you have read the thread on tractor winches you could easily see that the truck itself could loose its footings and slide sideways Oh never mind. :D
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Saw Anywhere!
