Get your Forestry Forum Hats while they last!
I see you're in Pennsyltucky, did Dan Henry build that for you? I have a couple saws he built for me about 7-8 years ago, still running strong.
sorry dude, but i would MUCH prefer to hear the engine. that unintelligiable, throat-screaming, music is just racket enjoying mine still.
Quote from: nmurph on August 09, 2010, 11:02:35 pmsorry dude, but i would MUCH prefer to hear the engine. that unintelligiable, throat-screaming, music is just racket enjoying mine still. Well what he didn't tell you but I will is the fact his sound went out on his camera .I've seen the clip before .
And that plunge cut indicated that it was a hollow log.
Here it is, my woods ported 064/066 cutting 4' oak.
if the log was hollow you would've saw a bunch of rotten crap coming out.
Quote from: MMFaller39 on August 08, 2010, 02:19:53 amHere it is, my woods ported 064/066 cutting 4' oak. It wasn't my bubble. Your OP stated that you were "cutting 4' oak". It's obvious on the plunge cut that you ran out of tree, which means that it wasn't 4', as your OP indicated, where you were sawing .Quote from: MMFaller39 on August 10, 2010, 01:05:44 pm if the log was hollow you would've saw a bunch of rotten crap coming out. Not necessarily so.I wasn't trying to be argumentative, just commenting on the sudden movement on your plunge cut. Had it been a solid 4' log, that movement would not have occurred.It's cool man, the tree was 4' on the stump, but it was lacking wood in the back. When I made this video my intentions weren't to try and make my saw "look" faster then it is. I've taken the saw apart twice since I made the vid doing more work to it each time. I built the special just for when I cut bigger timber, the saw wasn't made at all to run a bar under 30", slap a 32"er on it and it rips like nobodies business.
Is that used for competition or what? Fallers here don't want to work that fast.
That there is my beef with most modded saws. The excessive volume level isn't worth the performance gain.Hearing aids ain't all there cracked up to be, ask someone that wears them.I ran my factory dp 046 against a modded 2186 J-red a while back....while I didn't flat out beat him, it was so close it wasn't funny. Best part was I couldn't hear my saw, the Dang J-red was so loud I had to go totally by "feel" in the cut. Yes, I had hearing protection. End result, the J-red found a new home, I muffler modded a new 460 to match my old 046 for the former J-red owner.Ed
