BID ON A FORUM AUCTION!
Leaving the boards rough brings up our second quandary and that is should we sand the floor after installation or plane it before installation?..... and am very appreciative of the comments from you all.Tim
Again I apologize for my ignorance...
I'm only curious, but would fire killed wood be considered green if it has been standing for 4-5 years? Also, how much would rainy weather contribute to moisture content? It has been raining where the wood has been standing, where it has (will be) cut and where it will be installed.Tim
Quote from: bobdog on July 31, 2010, 01:00:02 amI'm only curious, but would fire killed wood be considered green if it has been standing for 4-5 years? Also, how much would rainy weather contribute to moisture content? It has been raining where the wood has been standing, where it has (will be) cut and where it will be installed.TimI've milled old logs and the wood is drier then green but not dry enough to use as flooring or paneling indoors right off the mill.You may need to air dry the wood for sometime before you have it kiln dried. Or have it kiln dried right off the sawmill.Have you milled up any of the wood, yet?One way to tell if it is dry is to test it with a moisture meter. If you don't have a moisture meter an easy way to test to see if it is dry is to weigh it. Dry wood should weigh a certain amount and if your wood weighs more then it is not dry.Jim Rogers
