Get your Forestry Forum Hats while they last!
It might air dry in that period of time, but around here, that would mean that the moisture content might be around 15% - 18%. If used inside, it will dry some more and shrink some more, so if you put up the paneling on Labor Day, expect some shrinkage gaps to form between the boards. If you reverse the shiplap where the smooth side is toward the studs and the groove is showing on the room view side, then the additional shrinkage will probably not be noticeable.
I have never really paid that much attention to exact ambient humidity I just know I tend to have problems with drying too fast in the summer and our humidity can be below 10%. This year has been different here also. So far humidity has been pretty high. Very unusual. If it stays that way that will help. If you have dry logs then you should not have any problems. For the wet ones you could experiment with stacking and stickering in the shade. You can also partially tarp them but watch out very carefully for mold. Another method is to close them up some how. I have a shop that is pretty tight and that worked pretty well with a stack of black walnut. It gets to 80 or 90 degrees inside in late spring or early summer but the moisutre stayed in the air. It controled the drying time a little more and did not mold. I did open the door at night for a hour or so to get some air exchange. I would say just experiment with what you have and do what you can to slow the drying time. If you had a spot in the shade by a creek or pond that could even help a little. A basement is good also. If humidity is too high a fan may be needed.Let us know how it goes.
