Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: homelite & poulan clutch replacement  (Read 741 times)
davefrommd
  • Guest
« on: October 23, 2003, 05:50:49 pm »
I am going to replace the clutch assembly on my poulan pro 235 and a neighbors homelite super 2 chainsaw. I have never done it before. Could someone give me instructions as to how to do the replacement. I would appreciate your help greatly. Thanks  Dave
Offline Kevin
    • The Milling Masters
Re: homelite & poulan clutch replacement
« Reply #1 on: October 23, 2003, 06:37:58 pm »
Dave, they both come off the same way.
You have to stop the piston by removing the spark plug and use a piston stop tool or a length of starter cord in the cylinder.
The clutch nut comes off clockwise but make sure you have the proper size wrench/socket.
Offline SasquatchMan
  • Get it done.
« Reply #2 on: October 23, 2003, 06:58:38 pm »
Let's hear it for Kevin, who apparently has a blow-up parts diagram in his head, of every chainsaw that's ever existed... :)
Senior Member?  That's funny.
Offline Kevin
« Reply #3 on: October 23, 2003, 07:04:23 pm »
It's a gift.  :D
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #4 on: October 23, 2003, 07:17:58 pm »
Yea, yer gifted alright... ;)
Offline Chet
« Reply #5 on: October 23, 2003, 07:40:28 pm »
When using the rope in the cylinder trick, it is a good idea to remove the recoil first. This is done to keep from putting undo stress on it when turning the clutch retaining nut. Also, watch for the piston to be in the top 1/3 of the up stroke before inserting the cord. This is done to prevent it from being jamed in a port.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Kevin
« Reply #6 on: October 23, 2003, 07:47:50 pm »
Did you experience that?   :D
davefrommd
  • Guest
« Reply #7 on: October 23, 2003, 07:56:18 pm »
Hey Kevin, Thank you very much for your help. I looked at the threads and will be sure I remove the nut the correct way. I have the 10th edition book with all the chainsaws in it and will look at that as well later on tonight. I wanted to hear a hands on approach to removing and reinstalling a clutch. You've been a big help.
I decided to  fix that poulan pro 235 chainsaw and with the good help I received on this forum I think the repair will go just fine. Thanks again. Dave
Offline Chet
« Reply #8 on: October 23, 2003, 08:06:14 pm »
More than once someone has called me, that their saw is JAMMED after they replaced the clutch.
Offline Kevin
« Reply #9 on: October 23, 2003, 08:09:05 pm »
I believe it.
I use the tool, how did you free the rope from the piston?
Offline Chet
« Reply #10 on: October 23, 2003, 08:18:58 pm »
Usually I can get it free by just working the flywheel back and forth and cutting the cord off on the port. It is still a pain though cause you still have to disassemble to remove debris.
Offline Kevin
« Reply #11 on: October 23, 2003, 08:23:41 pm »
The stop I have is aluminum, they say the plastic jobs break because of the angle just in case anyone is thinking of buying one.
Saw Anywhere!
