Hey gang, I was given a Poulan Pro 4620AVL by a co-worker and was told "This POS does not stay running / run right so take it"...
well, sure it's gonna run like crap with no air filter and 50PSI. So I took it apart and the ring was shot, the bore looked salvageable so i cleaned it up a little and ordered a new ring for the piston. I'm keeping this on the cheap since this will be my camp saw....
I AM NOT A PRO... I fix ejection seats as a job...but I did have good luck rebuilding a Husqvarna 55 so I wanted to give this a try.
anyway, I quickly learned not all saw crankcases are the same.....
I have cleaned everything, checked stuff ( as best i know) but i am puzzled as to what to use for the "bottom end" crankcase sealant... it appeared to have some sort of RTV as a sealant from the factory.
All of the standard RTV / gasket makers I have in my garage seem to shy away from "constant immersion in gasoline" Do they mean as a gas tank repair or would the environment of a chainsaw be bad for it?
so what do I use?
thanks, Jim
