Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Why does saw cut better on a curve?  (Read 1779 times)
Offline terrifictimbersllc
    • Terrific Timbers LLC
« on: May 12, 2010, 08:22:29 am »
I've noticed, I think when chains are getting worn, that a sharp chain will still cut very easily but only if I let the cut curve around to the left as I go through the log. When this is happening, if I restrain the saw trying to make a straight cut,  it just won't saw.  Anyone know what causes this? Bar top not square? One side teeth shorter than the other?   ::)
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline Kevin
    • The Milling Masters
Re: Why does saw cut better on a curve?
« Reply #1 on: May 12, 2010, 09:04:29 am »
The rakers or depth gauges could be longer on one side and not cutting as much wood on that side of the chain.
Offline John Mc
« Reply #2 on: May 12, 2010, 09:37:41 am »
Bar rails work unevenly?
Small time fire-wooder in a neighborhood cooperative.
Offline Sprucegum
« Reply #3 on: May 12, 2010, 09:44:41 am »
My saw cut like that when I was first learning how to sharpen the chain. Being right-handed, one side was getting sharpened better than the other. Once I learned to treat both sides evenly the cut straightened out.
Offline JohnG28
« Reply #4 on: May 12, 2010, 10:56:41 am »
I think Sprucegum could be right.  If you favor one side of the chain when sharpening you will have this effect.  Is it possible to have the chain sharpened at a shop where they can put it on a grinder and even them out?
« Reply #5 on: May 12, 2010, 11:33:14 am »
When it stops raining I'll have a close look at one saw which is doing it now.  Grind periodically on the grinder to get teeth the same length.  Pretty sure I'm treating both sides evenly on hand filing but who knows.
« Reply #6 on: May 12, 2010, 12:21:22 pm »
It doesn't necessarily have to be something you are doing.   If you hit some dirt, a rock or a little nail, one side of the chain cutters might have been damaged more than the other side, so, one side will cut faster than the other.
When a saw begins to get a little dull, we are tempted to press harder and even use the bucking teeth more aggressively.  If you are right handed, you might be using your left hand to push down and where your hand is situated on the fore handle will determine which side of the chain gets the most pressure.  Hold the saw securely, but without pressing down, and see if it cuts straight.
Offline JohnG28
« Reply #7 on: May 12, 2010, 12:36:54 pm »
Thats a good point, it doesnt necessarily have to be an error in filing, but does point twards one side wearing more than the other.  Tried a new chain to see if that cuts different or better?
Offline Ianab
« Reply #8 on: May 12, 2010, 04:04:08 pm »
Thats what I would check if there is no obvious problem with the chain.
You should be able to take the bar off and stand it upright on edge, so it sitting on the rails. If they are worn unevenly the bar will keep falling over. If thats the case, flip the bar over and use the other side. If thats also worn, you need to get the bar dressed (ground down even). After it's been dressed a few times the groove will start to get too shallow for the chain drive spurs to run in. Then it's time for a new bar.
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline quietrangr
« Reply #9 on: May 13, 2010, 06:12:15 am »
Put the chain in a new bar. If you get straighter cutting the problem is more likely that the chain drivers are worn, and the chain is simply laying over, or sort of flopping over to one side. This will happen sooner if the bar is also worn. I generally run a chain through at least two bars, a worn one when the chain is new, a less worn bar when the chain is midway, and a new bar when the chain is getting toward the end of its useful life.
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #10 on: May 13, 2010, 10:22:48 am »
Gday and firstly welcome to the Forum if i havent already said Gday Mate  ;) ;D 8) 8)
Itll most likely be either one of them  ;) but its a tricky thing to rectify in a short post and its 12.30am here im knackerd and  headn to bed  ;) if someone can please bump this back up tomorrow ill go into afew diferent ways you can fix it easy mate  ;) ;D ;D  8)
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline timber tramp
« Reply #11 on: May 13, 2010, 12:14:17 pm »
    >>if someone can please bump this back up tomorrow ill go into afew diferent ways you can fix it easy mate
Regards Chris
        Bump, there you go Chris.           :) TT
Cause every good story needs a villan!
Offline thecfarm
« Reply #12 on: May 14, 2010, 06:25:27 am »
I hand sharpen and take more off on one side than the other. I just take one less stroke when the motor is on the right side when I sharpen the chain.Been doing this for more than 20 years,works for me. I can bring a chain back from hitting a rock or when I cut a stump down with 3-8 trees growing out of it.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline John Mc
« Reply #13 on: May 14, 2010, 09:33:36 am »
I'd still take a good look at the bar rails. I had those exact symptoms. The first time I really noticed the saw wanting to wander off to one side, I thought I was doing it by how I held the saw. I could force it to go straight but after a while the curving tendency got worse... enough so that the saw bogged down as it got deep enough for the back side of the bar to enter the cut.
Squaring up the bar rails with this Pferd Universal Edge Sharpener (in stock at forum sponsor, Baileys) took care of the problem. I bought it right after my local saw shop diagnosed the problem and trued up the bar on their belt sander (which had a little table to hold the bar square to the belt).
If you think about the geometry of this, it makes sense. If one of the bar rails is worn more than the other, the chains will be slightly tilted out of the plane of the bar. It will cut towards the tilt. It doesn't take much to cause this... it's often something you can just eyeball while it's on the saw. In fact, the chain may sit square, resting on one bar rail until it hits the log. Then it settles on to both of the rails.
I'm not trying to claim uneven bar wear is the only cause of this problem. It may well be how the saw is sharpened. In fact, if you have a chain that is sharpened in such a way that the saw wants to cut on a curve, that can cause uneven bar wear. As you try to adjust your pressure to keep the saw cutting straight, you'll accelerate wear on one of the bar rails. This can give you a "double-whammy" - both the chain and the bar are trying to push your cut into a curve. Putting on a new chain may improve things slightly, but the uneven bar will still make the saw cut on a curve.
Offline 01crewcab
« Reply #14 on: May 17, 2010, 10:01:50 am »
I would just about bet your right vs left hand cutters are filed to a different length. Most right handed people will will always tend to file the right hand cutters down farther than the left hand ones.
2100(2),480, 281, 181,372XPW, 460,435,350,61(4),51-Huskys
49SP, 630Super(2),830-Jonsereds
S-XL925 Homelite
790,250.1010S Macs
27Ton Troybilt Splitter
NRA Life Endowment Member
Viet Nam Vet
Offline HolmenTree
  • "Been there.....done that"
« Reply #15 on: May 30, 2010, 12:59:16 am »
Your chain is cutting to the left as your crosscutting down through the log, which only means your right hand cutters are much duller then the left hand cutters.
You probably hit some dirt or some abrasion while falling a tree dulling those right hand cutters, or hitting some metal etc while bucking a log.
I have had bars with uneven rails, sloppy spread as all heck, left hand cutters bigger then the right hand cutters ........ but as long as all cutters are sharp the chain will cut straight in a downwards cut. A felling cut with the b/c on its side is a different story.
If I rock out my chains on one side only, I don't try to sharpen all the cutters to the same smaller size . A little difference in left and right cutter size is no big deal as long as your not always cutting big logs taking up the total length of the bar.
Keep all those cutters  sharp and the bar rail kerf tight.
Willard.
Offline Brucer
  • The Kootenay Sawyer
« Reply #16 on: May 30, 2010, 02:01:59 am »
I cut curves a lot when I'm bucking Douglas-Fir in the log yard.
D-Fir has thick, fissured bark that hold (and hides) dirt real easy. Whenever the saw starts to curve I resharpen the chain and the problem goes away. Obvious conclusion -- cutters on one side dulled more than on the other.
I have had problems with the cutters on one side filed shorter than on the other, but only when the rails were spread open. I've also had problems with the depth gauges filed differently on one side versus the other. Again, this only showed up with the rails spread.
So, sharpen first, then look for other issues.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline arojay
« Reply #17 on: May 30, 2010, 10:51:15 am »
Yep, sharpening issues are cheapest and easiest place to start.  Pick up a filing guide of some kind.  Carlton file-o-plates are great IMHO, but there are several kinds.  If you are assured that your chain is filed correctly then move on to bar issues.  Spread or uneven bar rails are best repaired with some special tools that may not be worth the money if you don't cut a lot so a good dealer or repair shop might be the way to go.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Offline SawTroll
« Reply #18 on: May 31, 2010, 03:07:19 pm »
Yes, that is most likely the cause!   :)
Firewood saws: Jonsereds Raket 621 (1970), Husky 353G, Stihl MS361W, Husky 372xpg, New Edition Husky 339xp, Dolmar PS5100SH, New Edition Husky 346xpg, Jonsered 2153WH, Husky 560xpg.
Online ladylake
« Reply #19 on: May 31, 2010, 04:44:37 pm »
I bought a saw off Ebay once that had the links where they hit the bar on the chain wore off more on one side, that one took a while to figure out, chain went in the garbage.    Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Saw Anywhere!
