Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: New to Chainsaws - which one?  (Read 1686 times)
Offline Kersh
« on: May 06, 2010, 06:06:02 pm »
Hi,
I'm based in the UK and need a chainsaw for light work chopping wood for the fire, prining trees, cutting down small trees etc. Having used a bow saw for this work in the past, I want to buy a chainsaw to make my life easier. I work for a company that use chainsaws but that is pretty much the limit of my knowledge. As a result, i'm faily apprehensive about buying one!
I need some advice. It appears from my limited research that electric chainsaws seam to be less powerful, safer, easier to maintain and quieter. I will only be using the saw occasionally so this sounds like a good option right?
I assume I will pay more for things like more power, better quality saw, etc. etc. What should I be looking for.
What is the minimum protective equipment I would need? Gloves, eye protection & trousers?
Any advice would be great.
Offline nixon
Re: New to Chainsaws - which one?
« Reply #1 on: May 06, 2010, 09:06:00 pm »
I guess that I'll start the ball rolling by asking  a few  questions .
How much do You have budgeted  for a saw ?  How much wood ,and how often will You be cutting ? Are You comfortable maintaining fuel powered equipment ?
Offline WDH
  • April 1998 - August 2008
« Reply #2 on: May 06, 2010, 09:16:57 pm »
You need a safety helmet with a wire mesh faceshield and fold down earmuffs.  You need chainsaw chaps.  I have an electric Makita chainsaw for light use around the sawmill.  It is small and light and could handle wood up to 8" or so in diameter.  But, you are confined to the distance you can use it from the power outlet.  That is a major disadvantage.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline nixon
« Reply #3 on: May 07, 2010, 01:45:11 am »
Darn , You use an electric chain saw and wear all that ?  I'll bet You wrap yourself up in bubble wrap before riding a bicycle  :)
Offline bandmiller2
« Reply #4 on: May 07, 2010, 07:46:10 am »
Kersh,if you can live with the cord restrictions of an electric,it is by far the least hassel.You can judge the quality of an electric quite well by price,I would stick to a name brand for parts availability.I use a Milwaukee electric with a 20" bar around my mill very handy and it starts easy.You must become adept at sharpening as electrics are not over powered.Frank C.
Offline John Mc
« Reply #5 on: May 07, 2010, 11:01:50 am »
About the only safety equipment I might leave out of WDH's list is the ear muffs. I'm guessing an electric is quiet enough that hearing protection is not necessary. (I might have the muffs on just out of habit.) Everything else is something I'd use for any chainsaw.
One thing about electric motors: if they bog down in the cut, they won't lose torque like a gas saw will. They will still be trying to horse that chain around the bar. Don't think you can treat them like a toy just because they are not gas-powered.
Small time fire-wooder in a neighborhood cooperative.
Offline maple flats
  • Life is what you make it!
« Reply #6 on: May 07, 2010, 08:06:01 pm »
A long time ago I had an electric chainsaw. I don't remember the make for sure but I think it was either Remington or maybe a Makita. It was very slow in the cut, the bar oiler was just a reservoir with a small hole over the chain, when you pushed on the cap it worked like an oil can and dripped on the surface of the chain if the saw was upright. The saw was not good enough to cut much of anything. The bar was about 12" but it was real slow if you had anything over about 6" hardwood, maybe 7 or 8" soft. I also had to keep the chain fully sharp or it would not cut at all.
I hope the electrics are better now if you are considering one.
logging small time for years but just learning how, with a Forest stewardship plan, 2 compact Ford 4x4 tractors, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, sugar maple/maple syrup a hobby gone amuck.
Offline WDH
« Reply #7 on: May 07, 2010, 09:28:12 pm »
My comment was to meant to apply to chainsaws in general, especially gas powered ones.
Offline nixon
« Reply #8 on: May 07, 2010, 09:51:22 pm »
I know that . It's just that My inner dork got the best of Me  :)
No offense meant to You ,and if there   was , accept My apology .
I wear PPE as well when I cut .
Offline WDH
« Reply #9 on: May 07, 2010, 10:39:40 pm »
None taken.  Your description about riding the bike created a visual picture and I smiled as I thought about being wrapped in bubble wrap.  Too kinky for me :D.
Offline Kersh
« Reply #10 on: May 16, 2010, 04:00:38 pm »
Thanks for all the advice.
Nixon, to answer a couple of your questions, i'm probably going to be using this saw for between 2 and 3 days in the summer, maybe a day in the winter but other than that, not much. Although i'm in the UK, I have an apartment in Austria with a wood burning stove and trees around me that require some cutting back. I've used bow saws in the past but hey, i'm on holiday and want spend more time walking and climbing rather than getting blisters on my hands choping limbs off trees!
I'm looking to spend between about £100 to £150. What's the Husqvarna 317el 14" or the Husqvarna 321el 16" like? Anyone got one? They seam pretty good saws. Someone has also recommended to me that I have a spare, sharpe chain too - is that necessary if i'm only using it occasionally?
About the protective clothing, I think i'll buy at least trousers, boots, gloves and eye protection. I wasn't going to bother with ear protection if using a electric saw.
Do I seam to be heading in the right direction?
Offline chevytaHOE5674
« Reply #11 on: May 16, 2010, 04:38:38 pm »
Keep in mind that most saw chaps or trousers DO NOT offer protection against electric chainsaws. Chaps work by having the fibers clog up the clutch and stop the chain. Electric saws have no clutch and will cut right through most chaps and pants without batting an eye (seen it first hand).
Offline Kersh
« Reply #12 on: May 16, 2010, 05:04:58 pm »
chevytaHOE5674, thanks for the pointer!!! :o There must be some protective trousers you can wear though?
Offline Kersh
« Reply #13 on: May 16, 2010, 05:10:25 pm »
Ok, i've just had a look at the spec of the Husqvarna 317el 14" and the features include a Inertia-activated chain brake and a Chain catcher stud. Like I said, i'm a complete beginner here ... would the trousers stop the chain with these features?
Thanks again.
« Reply #14 on: May 16, 2010, 05:54:20 pm »
Probably not, the electric motors just have so much torque that they will cut right through all the chaps I've seen. Many manufactures state right on their chaps that they will not stop an electric saw. They may give you an extra second before your leg is amputated but nothing like a gas saw and chaps.
Quote from: Stihl Website
WARNING FOR ELECTRIC CHAIN SAW USERS!
The fibers will not stop the sprocket on most electric chain saws because of their constant high torque.
Quote from: Swedepro chaps
Note: These chain saw chaps cannot be used with an electric chain saw. An electric chain saw has too much torque.
Offline JHBC
« Reply #15 on: May 16, 2010, 07:54:49 pm »
Hi Kersh,
I don't know what prices are for saws in the UK, but if you're only using it a few days a year, buy a good used saw.  A smaller pro saw with a 20" would do fine. A Husky 346 or Stihl 361, both great.  Stick with a good quality unit, try the used market, and buy a few chains, until you get used to keeping them razor sharp.  More powerful saws with bigger bars are great, but you probably wont justify the cost.  Cheap saws just suck, and will drive you nuts with frustration.  Use what the pros use, just think smaller, and used.
MS460 28"    MS441 20"/24"    394XP 32"/36"    064AV 24"  3120XP 32"/42"
Offline Cut4fun
« Reply #16 on: May 17, 2010, 10:56:00 am »
Oops my bad I posted info in wrong thread  :-[. So I will cut and paste
Learn Chainsaw Repair ChainsawRepair
Offline JHBC
« Reply #17 on: May 17, 2010, 10:59:05 pm »
Hi again
My recommendation for the ms361, 346xp saws, was because I have used dozens of saws: 080's, I have a 3120, a couple of mid sized saws too.  And have owned lots of others small, big, expensive, cheap.  I know that buying an underpowered, or problem plagued saw is worse than not even owning one.  P.S. Get some fallers pants, and a get face/hearing protection unit.  It might seem a bit much, but when that idling chain nicks your Kevlar, you'll be glad you didn't buy those couple of dinners out.  Money can be replaced.
I like Cut4Fun's saw choices.  If you like large saws, and have the cash. By all means a 395 is tons of fun.
Offline SawTroll
« Reply #18 on: May 22, 2010, 05:13:24 pm »
At least they are harder to stop than gas saws - more fibres need to be pulled into the sprocket area before they stop.
Firewood saws: Jonsereds Raket 621 (1970), Husky 353G, Stihl MS361W, Husky 372xpg, New Edition Husky 339xp, Dolmar PS5100SH, New Edition Husky 346xpg, Jonsered 2153WH, Husky 560xpg.
Offline SawTroll
« Reply #19 on: May 22, 2010, 05:21:33 pm »
Thanks again.
Sorry, those features have nothing to do with how well protective garment works!
Saw Anywhere!
