Get your Forestry Forum Hats while they last!
Dont forget medical card, log book and pretrip inspection if your hauling heavy. We could go on and on, triangles, fire extinguiser, combo plate, blah blah. Of course RV's are exempted here in Pa. to my knowlege As if some retired overweight guy driving it isn't as liable to have an accident, (perhaps strong RV lobby?) Ironwood
For example in Minnesota, the state licenses all 3/4 ton pickups as passenger vehicles only and will fine you if you buy a truck license for that pickup. The reason is the passenger vehicle license costs as much as 5 times more that a weight rated truck license.
Pulling a load that has a gross of about 9 ton with a truck that weighs about 3.5 ton is just plain crazy. IMO. That size truck was not designed to pull that size of payload. Yes they will pull it and if you are careful it will also stop it but at what cost? How often do you need to move it? For that size combination you must have a class 1 CDL to drive it unless you try to run farm plates and if you check with the RMV in your state you may not be able to run farm plates. If I had a machine of that size I would let someone else haul it and not have to worry about the liability.
