Get your Forestry Forum Hats while they last!
James, When I see a 2500 I think of it as a 3/4 ton. Was yours different?My 2 cents is a 1 ton would be OK, as you are within specs, but obviously bigger is better when it comes to towing. BUt since you already own one what do you have to loose? I have seen some deals on Goosenecks and I bet you would use it for lots of stuff if you had one.Dave
Here in PA with the amount of guys moving cattle and other livestock to auction on a commercial scale, as well as a MASSIVE amount of natural gas development the commercial sector of our DMV has really started paying attention to the 1 or 1 1/2 ton trucks towing goosenecks that are rated over the 10,000lbs. Those setups require a class A license, so keep that in mind before you start hauling loads that heavy behind a dually pickup.
Quote from: PAFaller on April 30, 2010, 11:06:31 pm Here in PA with the amount of guys moving cattle and other livestock to auction on a commercial scale, as well as a MASSIVE amount of natural gas development the commercial sector of our DMV has really started paying attention to the 1 or 1 1/2 ton trucks towing goosenecks that are rated over the 10,000lbs. Those setups require a class A license, so keep that in mind before you start hauling loads that heavy behind a dually pickup. Isn't that only the case if your combined weight is over 26,000 lbs.? I really don't know for sure, but I found this on the DMV's website:"CLASS A (minimum age 18): Required to operate any combination of vehicles with a gross weight rating of 26,001 pounds or more, where the vehicle(s) being towed is/are in excess of 10,000 pounds. Example: Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds)."
