Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: 353 DETRIOT OIL  (Read 2143 times)
Offline treefarmer87
353 DETRIOT OIL
« on: April 04, 2010, 09:01:24 am »
what is the best oil to run in a 353 detriot?
Amazing wife
1987 chevy 7000
Prentice H knuckleboom with FEC sawbuck
1980's Treefarmer C6D
Sthil 460 racesaw
Husqvarna 455
Sthil 360
Offline justintimemoto
Re: 353 DETRIOT OIL
« Reply #1 on: April 04, 2010, 09:17:54 am »
no clue about engines but i run valvline premium blue in my powerstroke and rotella 15-40 in all the tractors
ms660 372xp 455 rancher
2006 suzuki rm 125 for sale
Offline woody1
  • great family..great friends
Re: 353 DETRIOT OIL
« Reply #2 on: April 04, 2010, 09:28:35 am »
I have a 471. I was told to use only 30 reg.
Woody
If you don't want to row, get out of the boat !
Offline stonebroke
Re: 353 DETRIOT OIL
« Reply #3 on: April 04, 2010, 09:49:52 am »
I think that recommendation dates back to ancient days when the detroit was designed, back then there were no multiple grade diesel oils.
Stonebroke
Offline tlandrum
Re: 353 DETRIOT OIL
« Reply #4 on: April 04, 2010, 10:06:33 am »
i run 15-40 in my 3-53
when all else fails dig in and just work harder
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: 353 DETRIOT OIL
« Reply #5 on: April 04, 2010, 10:15:13 am »
I ran into the same problem when I got my TJ with 3-53. There was a whole list of single weight oils recommended to me depending on different temps, atmospheric conditions, and phases of the moon. It's got 15-40 in it now, and that's what I run in all of my trucks and equipment. The local Mobil guy couldn't even get me straight 20.
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Offline timberjackrob
Re: 353 DETRIOT OIL
« Reply #6 on: April 04, 2010, 10:22:44 am »
ive always run rotella 15w40 i also use lucas heavy duty oil stabilizer.
208 timberjack woodmizer lt28 case 455 trackloader massey 481 ford f250s
Offline quietrangr
Re: 353 DETRIOT OIL
« Reply #7 on: April 04, 2010, 10:28:10 am »
When I had a 353 the dealer was adamant about straight 40 Delvac, specially designed for those engines. You can also find a lot of info by searching online. Naturally, you can't use 40 wt in the winter, but it will keep you going while you do some more research.
Offline John Woodworth
Re: 353 DETRIOT OIL
« Reply #8 on: April 04, 2010, 01:19:28 pm »
I only use Chevron products my self and in my case use Dello 400 40 wt year round, thankfully don't have to fight the cold temps. most you guys have, it is a good Deisel grade oil, however the true grade for Detroit in the Chevron line is Dello 100 30 wt. Texaco Ursa and Shell Rotella are comprable oils and are ment to slightly sludge. Detroit recommends MIL-L-2104B 30 wt. year round and does not recommend any vis. lower than 30 wt. or multi -viscosity oils, consult with your local oil supplier and he can help you.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026
Offline mburrow
Re: 353 DETRIOT OIL
« Reply #9 on: April 04, 2010, 07:07:37 pm »
here is a tread on the same subject
http://209.164.108.37/board/index.php/topic,28492.0/all.html
my reply there is the same as I would put here
Offline den
Re: 353 DETRIOT OIL
« Reply #10 on: April 04, 2010, 08:27:58 pm »
I have a warning lit. from Detriot not to use multi-viscosity oil. It goes into why but I can't remember the reason.
I'll try to find it.
Shell recommends straight weight oil.
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/zzz_lhn.html&FC3=/rotella-en/html/iwgen/oem_spec_home.html
Detroit Diesel / Mercedes
2006 and older DDC series 40, 50, 55, 60 4-cycle diesel engines 2006 and older MBE 900, 4000 diesel engines
 DDC 93K218, 93K214,
API CJ-4, API CI-4 PLUS
 Shell Rotella® T6 Full Synthetic 5W-40
Shell Rotella® T5 Synthetic Blend Technology 10W-40, 10W-30
Shell Rotella® T Triple Protection® 15W-40
DDC series 53, 71, 92 2-cycle diesel engines
 API CF-2, SAE 40, SAE 50 (SAE 30 when below 32º F ambient temperature
 Shell Rotella® T1 SAE 40, 50
(Shell Rotella® T1 SAE 30)
Homelite SuperXL, 360, Sotz 20lb. Monster Maul
Offline captain_crunch
Re: 353 DETRIOT OIL
« Reply #11 on: April 05, 2010, 12:03:34 am »
We ran 30wt Dello 400 in ours or should I say ran Dello 400 all over it ;D ;D Leakingest critter I ever seen
Offline ScottAR
  • eat mo' ribs...
    • n/a
Re: 353 DETRIOT OIL
« Reply #12 on: April 05, 2010, 12:21:24 am »
Delo straight 40  at least in the summer, lower weights for cold weather.
Multi visco oils are not good for em.
Scott
[Magicman]
Offline KyMasterLogger
Re: 353 DETRIOT OIL
« Reply #13 on: April 05, 2010, 04:50:31 pm »
whatevers the cheapest, its all gonna be on the outside of the engine by the end day... :D
Offline Maine372
Re: 353 DETRIOT OIL
« Reply #14 on: April 05, 2010, 09:33:49 pm »
the machine im working with now has a 4-53 and the company provides us 10-30.
run any oil that will stay in the motor.
you know a man runs a detroit when he buys 6 cases of oil and one filter.
Re: 353 DETRIOT OIL
« Reply #15 on: April 07, 2010, 12:59:19 am »
I've already voiced my opinion on oil so won't go in to that, I have two 353's, they are well maintained and non Eithered motors and do not leal a drop or use a drop in 100 hour cycles.
A leaking engine in not a well maintained engine and chances are your leakers have been started with either cold and you've taken the top edge off compression rings and by using multi- vis are getting eccessive amounts in the airbox, if it's a motter of gaskets leaking fix it, for the cost of a motor you can't be cheap and run any old oil and run what Detroit recomends, overall engine life is what matters.
Offline barbender
Re: 353 DETRIOT OIL
« Reply #16 on: April 07, 2010, 10:31:18 am »
I don't understand, what exactly is the problem with the multi-vis in a 3-53? I was going to just put 15-40 Rotella in mine, that's what I run in the other rigs. Now I'm not so sure.
I just want to run my mill
Offline GRANITEstateMP
Re: 353 DETRIOT OIL
« Reply #17 on: April 07, 2010, 03:46:17 pm »
15w40 Shell Rotella
Offline ScottAR
  • eat mo' ribs...
    • n/a
Re: 353 DETRIOT OIL
« Reply #18 on: April 07, 2010, 07:54:01 pm »
Scott
[Magicman]
Offline redcedar
Re: 353 DETRIOT OIL
« Reply #19 on: April 07, 2010, 10:14:38 pm »
     I run chevron 15w-40 in 1979 c5 tree farmer
millitary five ton with bc loader 8000 hood   79 treefarmer cable skidder , two 575's husky
Saw Anywhere!
