Get your Forestry Forum Hats while they last!
I am looking to buy a truck to haul my own logs and studwood to mill. the mills are all within a reasonable distance. sawlogs 40 km, studwood 35 km and low grade pellet 9 km.I am looking at a 1 ton truck and loading with a farm tractor. The truck could also be used in the winter for plowing and sanding.
In Wisconsin if you are a farm business (logging/tree plantation is considered farming) you are then exempt from the CDL requirements as long as the produce is your own and you are carrying it to the mill. You are limited by a 150 mile direction from the farm and you can still be fined if you exceed the total capacity of your equipment.
