Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: sawing yellow poplar - whats the secret?  (Read 2235 times)
Offline dad2nine
  • If you aren't making mistakes, your not doing nothing
« on: March 29, 2010, 12:00:54 am »
I mainly saw hardwood and my mill does pretty good at it, as a matter of fact it's rare I saw any softwood. But yesterday I tried to saw up a some poplar and the blade wandered all over the place :(
My customer also had 8 Red oak and 4 hickory logs that I cut up good and straight. After I messed up two tree top poplar logs, I gave up and told the him I would come back after I figured out what I was doing wrong. Thankfully he was pleased with the hickory and red oak and paid me for that lumber. He also understood that I was having problems and said no problem. Seems when the blade hits a knot it would throw the blade off and it would rise or dip. What's the secret to sawing poplar on a band mill?
Offline customsawyer
  • www.thecustomsawyer.com
Re: sawing yellow poplar - whats the secret?
« Reply #1 on: March 29, 2010, 04:58:42 am »
If you sawed hickory with out any trouble then I would think poplar would cut pretty easy.
Online ladylake
« Reply #2 on: March 29, 2010, 05:04:28 am »
Normally poplar saws like butter, if the logs were a little dry try more set.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: March 29, 2010, 05:26:55 am »
Lots of times, Poplar does it's moving "after" the blade gets through it.
I don't remember the band being deflected while sawing Poplar on my mill.
Usually the knots are fairly soft and almost go unnoticed as they are being sawn.
My only suggestion as stated in the earlier posts, make sure you have enough set.
You might also keep an eye on your blade tension.
Did you try reducing your feed speed?
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Online Ron Wenrich
« Reply #4 on: March 29, 2010, 05:46:30 am »
I can't comment on the band mill, since I saw on a circle mill.  I've sawn millions of bf of tulip poplar.  Some logs will move after sawing.  Poplar moves more than red oak.  You also get into problems if you have spiral grain.
Offline ljmathias
  • Been sawing part-time 8 years now
« Reply #5 on: March 29, 2010, 05:59:48 am »
Wow, that's a puzzler- I've got a WMLT40 and have cut lots of yellow poplar.  If I have just one or two logs of that stuff, I save it till my blade starts to get dull, then put it on- like the man said, it cuts like butter, even with a dull blade.  Never had anything weird happen with it...
Don't mean to offend, but you sure it's poplar?  Maybe he cut some sweet gum and thought it was?  Maybe a picture or two would help- poplar that I've cut always has a distinctive texture and lots of color- hard to mistake for anything else.
Sorry, but I'm not much help on this one.  Hope a new blade gets it done.
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 45 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline Brad_S.
« Reply #6 on: March 29, 2010, 06:04:21 am »
I echo that yellow poplar cuts like butter. Did you put a fresh sharp blade on? To go from a hardwood to a soft with the same band will cause you problems, especially from hickory. Some don't realize there is a difference between cottonwood and yellow poplar, lumping them both under the poplar umbrella. Cottonwood is a little tougher to cut straight in but not that much different.
If you tried a sharp blade and still had issues, then it sounds like your blade may not be parallel to the bed or your guides are worn. IMO.
Offline Faron
« Reply #7 on: March 29, 2010, 08:16:39 am »
It sounds to me like you are sawing long logs,and 1 1/2  inch thick or more  lumber out of the upper, smaller logs. I have had problems with poplar under those conditions.  The DanG log flexes enough to make your blade dip and rise.  The only solution I have found is to shorten those problem logs if you can.  If you need 4/4 lumber, get it out of those logs as well.  I generally don't have a problem with larger, lower logs.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
Offline Qweaver
  • The cabin is done and we love it
« Reply #8 on: March 29, 2010, 08:33:36 am »
I have also sawed many thousands BdFt of Poplar without the problems you are having.  In fact, I just sawed 2 hickory logs and then went straight onto poplar without changing blades with no problems.
But saying this does not help you with your problem.  I guess I'd just put on a sharp blade and try it again.  The only time that I've had a blade move around in poplar was after I hit some iron with the blade.
Good luck finding the problem.
Quinton
So Many Toys...So Little Time  WM LT28 , 15 trailers, Case 450 Dozer, John Deere 110 TLB, Peterson WPF 10" :D
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #9 on: March 29, 2010, 09:20:53 am »
Being able to saw the Hickory and Oak, says that your mill is OK.  That leaves the blade and the log.
Diving blades generally indicate that you have hit something.  Also, a very dull blade pushed too hard may dive, but your sawdust will tell you that the blade is dull before then.
Logs will certainly move either up or down as stress is removed.  You were going through knots which indicate that you were sawing the smallest and least stable logs.
Fresh blade and a fresh start would be my advice.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline dad2nine
« Reply #10 on: March 29, 2010, 10:09:57 am »
After thinking a little more on this - I think it may be the blades...
What hook angle you guys using?
I'm using 4° - I see running the Wood-Mizer Blade Selector http://www.woodmizerblades.com/bladeselector/index.aspx I should be using 10 or 13° - I'll have to order a box and try them. I've only ran 4° on this mill.
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #11 on: March 29, 2010, 11:58:26 am »
I use a Wood-Mizer blade with a 9o hook for poplar (and everything else, for that matter) and it saws like butter. I've never had experience with the 4o hook, but I've always heard they were for very hard woods.
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
Offline Chuck White
« Reply #12 on: March 29, 2010, 12:35:59 pm »
I neglected to mention that I use Wood-Mizer 1¼ .045 10° blades exclusively.
I saw mostly W/Pine, R/Pine, Hemlock & Poplar.
I do saw some hardwood, but not a lot.
I really seem to have good luck with the 10° blades.
I LOVE MY SAWMILL
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #13 on: March 29, 2010, 12:44:11 pm »
 My Norwood does not like poplar, I have to have a very sharp blade or it cuts waves or dives in the cut. I have to change out blades often when cutting poplar. I even wash as much dirt out of the bark as possible. I cut oak, walnut and white pine mostly and do not have this problem with any of them.
Imagine, Me a Tree Farmer.
Jon, Appalatian American Wannabe.
Offline WH_Conley
    • Stone Hill Hardwoods
« Reply #14 on: March 29, 2010, 02:58:39 pm »
I saw a lot of yellow poplar. If the board has sawdust that is not cut clean, looks like it needs a shave, blade is dull. Little or no sawdust, too little set in the blade. Worst diving occurs when the blade is just starting to get dull, cutting clear wood, then get close to a knot. I think the reason is I am already cutting the full capacity of the blade and  the wood density changes.
Bill
Offline west penn
« Reply #15 on: March 29, 2010, 04:52:12 pm »
  I've always used 1 1/4 blades with 10* hook.  If your log surface is clean with no sawdust after taking a cut, use a little more set.
Offline sdunston
  • New York (the great tax state)
« Reply #16 on: March 29, 2010, 06:01:50 pm »
Sawing yellow poplar with my LT28 I use 10deg blades and have had good luck
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #17 on: March 29, 2010, 09:49:06 pm »
The 4 degree would have a low set and a tall tooth height. I would think a 10 degree would work much better. I have heard that using water on the blade will make the blade hydroplane in the cut. Green Poplar has a high moisture content and adding water makes it even higher. I have also heard that the blade will follow the growth rings if you use to much water in Poplar.
We saw lots of Poplar here also. Depending on the HP we would use a 10 degree or a 7 degree blade.
The 4 degree would be for Hickory or Frozen wood.
Hope this helps!
Marty
Red Green: If the women don't find you handsome, they should at least find you handy.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #18 on: March 30, 2010, 12:42:56 am »
I sawed about 5,000 feet of tulip this winter. When I started, I was using .055 10s, but then the wood froze, and I had to switch to .055 4s, then it cut fine again. I've got another 1,000 feet to saw on Wednesday, I'll start with the 10s and see how it goes. I did not use any lube on the poplar.
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Online ladylake
« Reply #19 on: March 30, 2010, 05:21:09 am »
 I buy new blades at 10* and sharpen them to 4* and they both cut like butter in poplar, I'd try some more set , sounds like they come without much set.   Steve
Saw Anywhere!
