Get your Forestry Forum Hats while they last!
Lets say you want to pull the trunk south; you need to make a box cut about 4ft high on the north side of the tree. your next cut will be on the south side. this cut goes toward the box but stops a good 1 to 2in from going all the way through. Tie your rope above the cuts and pull south. The back cut should open as the box closes moving the trunk a fair distance .
A box cut is another name for a face cut or notch cut or open face notch or conventional notch or cutting out the wedge or whatever people call it in their region. In this application an open face notch is preferable as the tree folds almost 90 degrees before the hinge breaks.
