Get your Forestry Forum Hats while they last!
Al, got a part number & brand on the fitting? I started tearing down my 026 for crank seals tonight.Ed
I was given that option to Joe. But didn't like the idea of whacking the crank shaft too well. You can't really hang on the the flywheel too well that way, since the crankcase surrounds it and only comes off when the flywheel is removed. Screws in behind the flywheel.
Well, if you still feel you're not upto that, the only other tool that can do the job is the Stihl flywheel puller # 1110 890 4500.Is this the image Al?(Image hidden from quote, click to view.)
