Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: I want to use all my sawdust !  (Read 1394 times)
Offline farlet
« on: March 10, 2010, 03:31:53 am »
I produce loads of sawdust from my mill and I want to utilise it for heating. I only have regular woodburners, so dont want to invest in a new system to burn it. I was in Sweden once and there was a guy who had made small discs about 3" across and only about 1/4" thick out of sawdust. They seemed to burn really well, but stupidly I forgot to ask how he made them.
I was thinking that I would need some kind of binding agent (Maybe wallpaper past because its cheap) and a simple press. Not sure if it would be a hand press or hydraulic.
I like the idea of using everything from the sawmilling process and not wasting anything. Has anyone done anything similar and was it succesful ?
I can fabricate anything, so I am thinking I will build something to do the job
Offline bandmiller2
Re: I want to use all my sawdust !
« Reply #1 on: March 11, 2010, 09:02:10 pm »
Farlet,I've always heard the natural lignin in sawdust will bind if their compressed.Try an experiment take a short piece of pipe and a short rod that fits in it put some sawdust in and use a press or bottle jack under a heavy machine and see what you get.Mayby pushing it through a restriction would give you large pellets,think of how a hay bailer works. Frank C.
Offline Oakcreek
« Reply #2 on: December 21, 2010, 07:57:31 pm »
Farlet!
I know this is an old posting, but I've been thinking of making a similar machine/device and wondered how you made out with your idea?
Offline west penn
« Reply #3 on: December 27, 2010, 09:49:14 pm »
oakcreek,  If you do attemp to build something, remember that the temp of the sawdust has to reach somewhere around  180 degrees for the lignin to become a binder. this is accomplished in pellet machines by the extrusion process. good luck!!
Offline Warren
  • Whatever you do, work at it with all your heart, as working for the Lord.... Col. 3:23
« Reply #4 on: December 27, 2010, 10:51:12 pm »
if y'all use the search fucntion. I am fairly certain there are other threads here on the Fourm that describe pellet making.   I think one term for the molded chunks of sawdust is "briquettes."  There are commercial machines to do this.  You could probably build something small scale to do the same thing if you're handy.
One of the twists is that the pressing process requires approx 20 to 25% moisture content to make a good solid pellet/chunk/briquette.  However, if they will be stored for any length of time, they need to be dried down to approx 15% moisture content to prevent mold/mildew...
AS always, if you do buy or build something ... pictures please !
Warren
LT40SHD42, Case 1845C, W&S Forklift, Baker Edger ...  And not near enough time in the day ...
Saw Anywhere!
