Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: think i might have damaged my load of QSRO, what do you think?  (Read 874 times)
Offline Kelvin
Howdy all,
Well i set my Nyle kiln at the conservative setting for my green QSRO load, and turned it on.  For some reason my life got hectic and i couldn't get around to oven drying my samples and getting things checked to see how my drying was going.  Well after 4 days i checked and the lumber samples were surface checked badly already and my samples were down to 30% MC from 61% start so i lost 29% in 4 days or roughly 7% per day instead of my target of 3%.
Man my kiln must have been leaking the moisture out as it was at 90 degrees and 20%compressor cycle, which i thought was hardly anything.  I turned off the compressor when i discovered what was happening and now with the compressor off the samples are loosing 3% MC per day just through the leaky chamber.  though i checked the main stack and its nowhere near as dry as my samples.  I think they were more in direct wind area, so dried much faster.  I'm still very worried about surface checking in my main stack, i can't see much, but they say you can't see all the damage that might have occured until you get till final MC range and they open up.  I can't see the surfaces very well either, but i'll cross my fingers.
 My samples are now about 5 days older than when i stopped the compressor and read 20%MC.  I cut new samples however from some bigger pieces i had left over from the samples and they are reading 32% MC.  I end coated the sample pieces so i don't know why there is such a difference in the dry rate on the samples, but man this is not an easy thing to do with oak.  I really need this stuff to turn out as i don't have the time or the money to wreck 800 bd ft that i'm using for a project i promised and is waiting on me.  I guess i can't tell how dry the main stack really is, i hope the samples are out of whack and its not that dry really.  Sweating bullets!
KP
Offline Kansas
  • In the mountains of Kansas
Re: think i might have damaged my load of QSRO, what do you think?
« Reply #1 on: March 10, 2010, 06:44:15 am »
Long as what your drying is 1" lumber, even with a leaky kiln you should be fine. 90 isn't that warm. I'm actually suprised you don't have water standing in the kiln. I would think the humidity of the kiln would be high.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #2 on: March 10, 2010, 07:25:31 am »
I use the Wood-Mizer controller (DH4000) on my Nyle and don't set compressor run time.   I just set RH and let it go.
I think the most important thing you can do is get the chamber air tight.   If you can't control a stable RH you're headed for trouble.    I lost the bottom gasket off one of my doors and didn't realize it until I ran into a way to rapid drop in RH.   Luckily I found the issues before I damaged the 1800 bf load of Walnut.
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline jim king
« Reply #3 on: March 10, 2010, 11:54:10 am »
Take a peice out and plane it.  It will either make ypu feel better or worse to know but at least you will know.
Offline OneWithWood
  • showing the past to the future
    • RWT Biodiesel
« Reply #4 on: March 10, 2010, 12:29:44 pm »
Let me echo what DR said.
When you are finished with this charge take the time to totally seal your chamber.  You cannot control the variables in a leaky chamber well enough to assure quality.
How long did the stack sit from the time it came off the mill until you fired up the kiln?
One With Wood
www.rwtbiodiesel.com
Offline Kansas
« Reply #5 on: March 10, 2010, 01:30:38 pm »
I just can't see damage at 90 degrees, set at 20% on the compressor.  The only way I could imagine is if you had a very high volume of air moving, coupled with not just a leaky kiln, but a well ventilated one. Not with 4/4 lumber.
Now, if its 8/4, thats a whole different story.
Offline Kelvin
« Reply #6 on: March 10, 2010, 06:38:40 pm »
Howdy all,
Yeah, i was hoping i couldn't wreck the 4/4 but the samples have me worried.  Has anyone had oak dry at over 7% MC per day?  I wonder if its easier to wreck it from 60-40%MC or 40-30%MC?  The lumber is still over 30% MC so i don't think i will see the damage until its down to 7%.
Offline petefrombearswamp
  • me & my son
« Reply #7 on: March 15, 2010, 07:09:17 pm »
Hey Kelvin, Off the subject, but I have often wondered, where did you get that nice bullfrog?
pete
LT40SHDD51
Kubota 900 RTV
241 acres of woodland
wife who understands my quirks
Saw Anywhere!
