Get your Forestry Forum Hats while they last!
yes i am sure it is better ,but do a pineywoods dual tooth conversion and it would give you a run for the money. pc
..... So here's what I do now. I marked the cam with two marks where the wheel touches down to its lowest point. I mount a blade and easily run the wheel to its lowest point using one of these marks, regardless of the height the grinder is set or the width of the mounted blade. Look at the "fit" with a light and adjust the "pusher", if necessary, so it fits perfectly. Now back off the wheel height adjuster till the wheel sets in the profile and I feel it getting loose, then take out the slack by turning it clockwise till I feel it just getting tight. That's it. Turn up the speed, turn on the oil and the wheel, and listen to the sound. If the grind sounds a little too heavy just turn the speed up a hair. Adjusting the speed can take the grinding depth a few thousandths one way or the other.
