1 turn out (thats quite a bit) and it pulls better , it's good you did this sooner rather than after it burnt up from being set to EPA specs. If you do get a tack the EPA spec RPM's are around 14300, I'd set them around 13800 to be safe and as you already found out these saws most time cut faster and have a wider powerband with more fuel. Steve
