Comstock Logging
Author Topic: cutting large log in half  (Read 10226 times)
Offline bandmiller2
Re: cutting large log in half
« Reply #20 on: March 02, 2010, 07:44:59 am »
They sell a product now for splitting concrete and stone you drill a hole put it in and it expands and cracks,forget the name but it works.Sometimes you can take your chainsaw and cut a groove then use common splitting wedges, sorta work the crack along.Only sure thing it's a buster.Frank C.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #21 on: March 04, 2010, 06:45:51 pm »
I saw large logs in half with a chainsaw mill.  52" width of cut.  Have Alaskan and Sperber mills.  Both are modified to have the option of deeper than normal cuts.   The Alaskan is a 56", and I bought two uprights from them with 36" long vertical bars. Eric at Granberg sold these to me. The Sperber has round aluminum uprights which are end drilled to mount at the top.  I made 3 sets of auxiliary uprights from aluminum of the same diameter, which I end-drilled on the lathe, tapped, and inserted a threaded stud of the same diameter/thread in order to make extensions which I add to the top of the mill's uprights to extend the depth of cut.  Have used it to quarter very large logs too big for the wood-mizer to quarter,  under 4' diameter.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline jdtuttle
  • If it's worth doin, it's worth doin right
« Reply #22 on: March 04, 2010, 08:23:14 pm »
Quote
OK Dennis, when do you want to come over to Candor & show me how it works? ;D
Jim
Have a great day
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #23 on: March 04, 2010, 11:17:37 pm »
I put the 5 bar on the big saw climb up on top of the log with a straight board as a reference and start down the length of the log. I finish both ends from the ground so that I am clear of the log when it falls in half. Then I put the 32 bar on and cut a 12 flat edge the length of each half or split it down the middle depending on the log. I got a big 52 fir that goes 30 before it gets small enough to fit on the mill. This would be a good log for a swing mill. Give me a few days to get to this project and I will post some pictures.
« Reply #24 on: March 05, 2010, 07:01:05 am »
Jim I'll let you know next time I'm setting up to do it. If you can't make it I'll send you a picture. dennis
Offline pnyberg
« Reply #25 on: March 05, 2010, 07:08:18 am »
Dennis (terrifictimbersllc), welcome to the Forestry Forum!
Dennis and I are part of the small fraternity of portable sawmills in Connecticut.  We're about an hour away from each other.
I would be interested in seeing a big log halved or quartered too.  If you're willing to have an audience, drop me a line the next time you have one of these jobs.
Thanks,
    Peter
No longer milling
