Jim, re fan speed I usually target between 300 and 350 FPM of air movement through the stacks when I'm drying oak, measured on the discharge side of the stack. This is based upon the USDA recommendation.
If you don't have an anemometer, you can use a handkerchief held behind the back of the stack. About a 30% deflection from straight down seems to equal 300 fpm.
