In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
BID ON A FORUM AUCTION!
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
The Forestry Forum
Forum
General Forestry
Forestry and Logging
(Moderators:
Ron Scott
Boundary Line Paint ??
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Boundary Line Paint ?? (Read 2904 times)
g_man
Full Member x2
Gender:
on:
February 25, 2010, 12:02:07 pm »
I want to repaint my boundary lines this spring.
What is a good paint to use?
I see that Nelson makes a special Boundary
Line Paint but I would have to send for it and
the shipping costs as much as the paint.
Is it worth it or is there a commonly available
paint that is useable? I have over a mile that
I want to paint.
Logged
Senior Member x2
Gender:
Knothole Sawmill, LLC
Re: Boundary Line Paint ??
Reply #1 on:
February 25, 2010, 01:11:33 pm »
The
right
thing to do is to use the right paint which would be what you are looking at. A "survey grade" tree marking paint. It is designed for that use and should last the longest.
That being said, personally, I don't always do the right thing. I go to my local hardware/paint store and look through their mis-formulated exterior house paints. Especially if they happen to have a red, I just get them to squirt more red into it. It generally cost about $5 per gallon. I have very visible lines that were painted 15 years ago.
There is another thread going (Dressing up property lines) about painting property lines that has good information in it.
http://www.forestryforum.com/board/index.php/topic,42312.0.html
Logged
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
Before you die.....Take time to live.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Raider Bill
Senior Member x2
Gender:
Oath Keeper
Reply #2 on:
February 25, 2010, 01:18:00 pm »
Is there a code about what differnt marks mean?
I have X's, slashes, O's, and combinations of the such as a X with either one of 2 slashes under it. Mine was marked by Bowater so I'm not sure if that's their code or if there is a universal one.
Logged
De inimico non loquaris sed cogites - Don't wish ill for your enemies; PLAN IT!
Nemo Me Impune Lacessit" -None shall provoke/injure me with impunity
poor farmer/logger
Full Member
Gender:
Reply #3 on:
February 25, 2010, 01:56:59 pm »
We just use the roles of ribbon to mark the outer edges of stands that we're going into to cut. Cheap and works fine. 10 and 15 years later the ribons are still there. Usually use a bright orange. When I'm on the skidder I can usually pick them out without much trouble.
Guess if your worried about someone taking off the ribons then it wouldn't work. We use a wood paint as well for makring species of trees at the mill. Think it's about 2.50 or 3.00 a can. if you buy it in case lots. it's made in canada though. Our local dealer has it here. Nelson tree and log paint it's called.
Just a thought for ya.
Ryan
Logged
downeast
Full Member
Gender:
Reply #4 on:
February 25, 2010, 03:28:43 pm »
We use tape also--blue works well though it is dark on cloudy days.
Paint---any oil based bright color to fill in blazes. Lobstermen use florescent colors ( sorry Canadians, "colours") on buoys. It lasts in saltwater a long time. I've used closeout paints at the local hardware store, cheap.
Logged
Chuck White
Senior Member x2
Gender:
Sawing mobile since 2005
Reply #5 on:
February 25, 2010, 03:43:26 pm »
As MM said! Go to the hardware store and look at paints that got screwed up when they were being mixed.
These can usually be had for $5.00 - $10.00 per gallon.
I would use
enamel
as opposed to
latex
edit: you should be able to have them mix and make a bright color out of one of their mistakes.
Logged
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan) - Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
Basic mechanical knowledge is all that's required to maintain the Wood-Mizer.
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Forester
Gender:
Large Tooth
Reply #6 on:
February 25, 2010, 03:56:34 pm »
I use fire red paint on my lines, Tremclad is the brand. It lasts a long time. I tried paint in a can from Nelson and it doesn't hold up and it's not very bright. I apply by brush on the old marks. You guys are lucky to get cheep reject paint, they charge the same for the mistakes as they do the other around here.
I'm going to re apply this spring before thinning season gets going and before flies and leaves come out.
The lines are still easy to see down, but I'm going to paint them just the same.
My front and back lines never need marking, road and USA border.
Logged
Pre-commercial thinning pays off.
Dirty Harry
stonebroke
Senior Member x2
Gender:
I'm new!
Reply #7 on:
February 25, 2010, 04:27:39 pm »
Whats on the border? A fence?
Stonebroke
Logged
Forester
Gender:
Large Tooth
Reply #8 on:
February 25, 2010, 05:07:54 pm »
A 66 foot wide corridor they keep brushed out. No fences of any kind, never was. Has monuments every 1000 yards or so. They just went through last summer again cutting it out. If you've seen my snow sled videos, they show the cleared corridor.
Logged
Dirty Harry
Ron Scott
Forester
Administrator
Gender:
Reply #9 on:
February 25, 2010, 07:22:45 pm »
We always use Nelson's boundary line paint for marking permanent boundary lines, but their "econo-paint" for marking trees for cutting which has a shorter retention span (2-3 years) and is much cheaper than the more permanernt boundary marking paint. It depends upon how long that you want the paint to last on the trees as to the quality paint that you use.
Logged
~Ron
pappy19
Senior Member
Gender:
Reply #10 on:
February 25, 2010, 07:39:29 pm »
If you want it to last, then get the Nelson's Boundary paint. I like their pink or white. It lasts a very long time and it's made in the USA.
Pap
Logged
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
woodtroll
Forester
Reply #11 on:
February 25, 2010, 09:43:33 pm »
We have had good luck with Nelson's. You may think about blazing with an axe also. The scar can last long after the paint fades. There is no code that is universal. We happen to put 3 strips so it is visible from a ways of. Flagging is good for temporary. Deer and elk like it, people pull it down and so on.
Make sure the line is in with flagging, then follow up with paint (and axe if you want blazes).
It is forestry improvement keep track of the expense and use it for tax purpose. Lines are not the spot I would be cheep.
Logged
indiaxman1
Full Member x2
Gender:
Reply #12 on:
February 25, 2010, 10:32:10 pm »
I have found both flags and paint fade with time....orange or pink ribbons show up nice for several years, but fade white.....orange paint also fades with time....I mark 1/4 section...80 acres rough ground every two-three years...prefer flagging
Logged
JimMartin9999
Full Member x2
Gender:
I need to edit my profile!
Reply #13 on:
February 25, 2010, 10:49:49 pm »
I use an adze to blaze. It is a lot more accurate and easier to use than an ax. The edge is perpendicular to the swing rather than parallel as with the swing of an ax. The blazes last as a scar forever. Keep them at the same height, which is the easiest height to swing at.
I ground out a roofing tool to form my own adze ; a lot cheaper than a true adze. If you go back a couple of weeks later and apply paint when the sap dries, you get the best of all worlds.
Logged
Jim
chevytaHOE5674
Forester
Gender:
Reply #14 on:
February 25, 2010, 10:55:53 pm »
I use Nelson boundary paint. Lasts a good number of years and isn't that expensive.
Logged
Ron Scott
Forester
Administrator
Gender:
Reply #15 on:
February 26, 2010, 08:20:21 am »
Nelson's is also a Michigan product and treats forester's well. Ribbon can also be easily removed by trespassers and more difficult in court cases when the judge asks if the boundary line was "permanently marked".
Logged
~Ron
Forester
Gender:
Large Tooth
Reply #16 on:
February 26, 2010, 08:32:11 am »
Funny, my Nelson paint says "Made In Canada at Sault Ste Marie, Ontario".
I've always bought it at the local Marketing Board office. This isn't boundary paint, just happens to be the only can I have. I used it for marking log ends when I scaled wood on sight inspections.
Logged
Dirty Harry
chevytaHOE5674
Forester
Gender:
Reply #17 on:
February 26, 2010, 09:10:31 am »
Nelson has like 4 plants across the country. But their corporate headquarters is in Kingsford MI, that's where I road trip when I need paint.
Logged
Ron Scott
Forester
Administrator
Gender:
Reply #18 on:
February 26, 2010, 02:27:14 pm »
http://www.nelsonpaint.com/history.html
Charlie Nelson, the founder was very active in forestry matters here in Michigan until his passing. He and his sales personnel always listened to us foresters in matters and ways to improve their products. They invented the paintball and initiated the paintball into a sport. Paintballs are now one of their main sales product.
I still have a calculater with the Nelson's Paint Company name on it which Charlie Nelson gave me years ago. He and most of his sale personnel that I knew well have since passed on.
Logged
~Ron
Forester
Gender:
Large Tooth
Reply #19 on:
February 26, 2010, 03:21:02 pm »
Ah, now I see says the blind man.
Logged
Dirty Harry
Print
Pages: [
1
2
All
Go Up
« previous
next »
The Forestry Forum
Forum
General Forestry
(Moderators:
Ron Scott
Saw Anywhere!
