Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Sticker size and lenth?????  (Read 1383 times)
Offline bikedude73
« on: February 21, 2010, 07:31:42 pm »
I went to help a guy with a mill and his stickers were short and I didn't know if there was a reason for that.  I would just cut stickers the length of the whole stack.  Any thoughts???????
Offline zopi
Re: Sticker size and lenth?????
« Reply #1 on: February 21, 2010, 08:06:16 pm »
Size doesn't matter.  :D
I prefer shorter stickers as it hurts my bloody back to bend over a wide pile of boards...but if you are banding to kiln dry ya gotta stack to fit the kiln cart...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline brdmkr
  • I need to slow down...
« Reply #2 on: February 22, 2010, 03:32:48 pm »
If stickers are too long, air flow through the stack will be reduced.  I like to limit my stacks to less that 48" wide.  Normally about 42" is what I use.
Offline twobears
« Reply #3 on: February 22, 2010, 04:51:56 pm »
 i like 1 inch x 1 inch square by 48 inches long.
 delbert
Offline red oaks lumber
« Reply #4 on: February 22, 2010, 05:58:30 pm »
i plane my stickers 3/4 thick rip them 1" wide cut 42" long, having the best stickers possible gives you the best air dried wood possible.
i know nothing related to wood
Offline woodmills1
  • the truth shall set you free
« Reply #5 on: February 22, 2010, 06:04:38 pm »
pine over 4 foot will mold right up here
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #6 on: February 23, 2010, 10:57:32 am »
I like red oaks' sticker size. If they are too thin or too long, you don't have enough air flow. If they are too thick, you waste a lot of space especially in a package kiln.
Offline fireman05
« Reply #7 on: February 24, 2010, 07:15:37 pm »
I have all of mine cut 3/4" x 1 1/2" x 48" and this has workew well for me in 16+ years of sawing & KD all types of lumber.  I have always made mine from northern white cedar so the sticker staining has been minimal.
I place the stickers about 16" apart and an 8' long pile will have 6 stickers per row.
Wood Mizer LT40G Manual, Nyle L200 kiln, Logosol PH260 Moulder, Kubota L4300 with Farmi winch
Offline Cedarman
    • Cedarusa
« Reply #8 on: February 28, 2010, 12:24:55 pm »
Two things very critical in stickering.  Same thickness stickers for each layer.  Stickers must be exactly on top of the one below.  Also bolsters or blocking must be under each row of stickers .
Offline bzsawyer
« Reply #9 on: March 14, 2010, 11:08:06 pm »
I agree most with Red Oaks and Cedarman for sticker size. We use 3/4 x 1 1/8 x 46''. Ash and Maple have worked the best for me. The 1 1/8'' wide seems to be strong enough to resist compression yet narrow enough to eliminate sticker shadow. And the 46'' length makes the packs just right to fit 2 side by side on the kiln cart. How ever the lumber is put up is the shape it will have when dry so careful stickering and skids under each stick row is a must.
Frick Timber Tiger TD36, 4 headblock, 56' of track. 56'' F style saw with 30'' top saw gives me 30'' of cut. Sawmill Systems setworks. Frick chain type log turner. Frick 641 3 saw edger, HMC ET10 trim saw, Morbark 48'' 3 knife chipper plus all the support equipment
Offline fishpharmer
« Reply #10 on: March 14, 2010, 11:55:24 pm »
bzsawyer, welcome to forestry forum.  Glad to have you here.
What kind of mill do you run?
I built my own band mill with the help of Forestry Forum.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #11 on: March 15, 2010, 09:01:09 am »
Welcome to The Forestry Forum bzsawyer.  I read your list of Iron.  Sounds like you have a "full deal".  Your experience will be valuable here on FF.   Again, welcome..... :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline inwoodcutter
« Reply #12 on: March 24, 2010, 03:59:23 pm »
I do the same as far as width of stacks. It does get to be a pain to do much wider and much narrower and the stack becomes unstable. Also the narrower stack will force you to stack higher, again making it unstable but also helping by adding weight upon the central boards.
I have to disagree that a wide stack will produce that much air restriction. Several high end commercial hardwood mills I know use 8 foot stickers. they simply have the equipment to handle that size load. Most of them do air dry for a while before they charge the kiln.
Dan
Dan Warner
"there's money in that slab"
Saw Anywhere!
