Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: log bundle forwarding with a cable skidder?  (Read 1022 times)
Online amberwood
    • www.amberwood.com.au
« on: February 13, 2010, 01:11:18 am »
wondering if anyone has any experience with this practice? Just looking at the tigercat site and it shows a cable skidder "forwarding"a bundle of CTL log ACROSS the beaver plates. It appears to have been stacked and then pulled up off the ground using two choker chains under the bundle and up throught the fairleads. We normally fell, skid and process on the landing, loading straight off the landing onto the truck. On a current site we can no longer get the truck to the landing due to some fences being constructed, and in the absence of a forwarder need to move the CTL log about a km from the landing to where the truck can turn around. Due to other restrictions we cannot process anywhere other than the current landing.
http://www.tigercat.com/604c.htm#
Thoughts?
DTR
MS460 Magnum
MS250
Koehring 618 Harvester-Rosin 975 Processor
CAT322BL Shovel Logger
CAT525A Cable/Grapple Skidder
Offline Bobus2003
Re: log bundle forwarding with a cable skidder?
« Reply #1 on: February 13, 2010, 01:20:28 am »
I have done it in the past, When i couldn't get a truck in due to mud..
Late 60's JD440, '94 JD550G, '94 Case 1845, '00 Link Belt w/'01 Patu 410SH Harvester Head, '99 Morbark 2090D, 2 - Stihl MS440
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #2 on: February 13, 2010, 07:57:57 am »
I have done this for years and still do it with firewood.We (piggy-backed) logs when we didn't want to get them dirty for sawing.When I did it I used the main line and the last choker on the main line and hung the rest of the chokers back up on the rear of the machine.Wrap the main line under the pile and center the cable half of the log pile then hook your choker as low as possible on the backside of your pile.When you winch in this will pull your log pile up to back of the skidder in a nice round pile.You will have to get the feel of when to stop winching,too tight and you will pop the choker and then your nice pile of logs is all over the place.We always picked a big old rotten tree or a blow down to pile the logs on.One more thing when hauling logs like that be careful side cutting hills because the load can shift and swing outside the wheel of the machine and tip you over.On a timberjack 230D or C5D Tree Farmer we used to haul about a cord and a quarter to a cord and a half with no problems at all.
Offline Jamie_C
« Reply #3 on: February 13, 2010, 08:33:38 am »
Around here we always called it "pack-sacking" and it was usually done on the worst ground where the older forwarders couldn't maneuver. Pile sizes varied but the main concern is flipping the machine over if the load swings.
Offline Frickman
  • Ouch, that hurt!
« Reply #4 on: February 13, 2010, 10:47:38 am »
We did that for years with little John Deere skidders when I was cutting mine posts. We would pull the cable out a ways, pile the posts crossways, and hooked the cable back on itself. Tighten it up with the winch and away we'd go. We would always have a hook on the end of the cable anyway so we would just use it.
Conventional hand-felling logging operation with cable skidder and forwarder, Frick 01 handset sawmill
Offline Twig farmer
« Reply #5 on: February 13, 2010, 11:10:58 am »
Gotta be a grapple skidder you can hire up for a day..
C5D Twig Farmer, Deutz power, "Mona".
Husky 575.
Husky 372.
F550 4x4 PSD.
Bull Strength and Ignorance.
Live FREE or die.
Online amberwood
« Reply #6 on: February 13, 2010, 03:29:59 pm »
thanks all. Might hold this method up my sleeve for a later task. We are using a TJ205, or a 208 as it is known in the rest of the world, and carting 3.9m lengths, might be just a bit tippy when you get a decent load on. Looked at hiring in a forwarder but there is only a few hundred tons left and the outlay would be greater than the sale price of the log! Still thinking.
DTR
MS460 Magnum
MS250
Offline nhlogga
« Reply #7 on: February 14, 2010, 05:24:49 pm »
DTR
Do you have fenders on the back of your TJ? If not the wood will rub on your rear tires.
jonsered 2171's/clark 664c
Offline aksawyer
« Reply #8 on: February 14, 2010, 08:22:22 pm »
If you ever look on some of the older machines with large back fenders,youll see a cocker sizer hole with a slot at the bottom.It looks kind of like a keyhole,only the slot does'nt get wider at the base.You would take your first two cocks in line run them under you logs up over to each slot on the fender and winch then in.The newer machines with out fenders,660 TJ,for example, wont work.aksawyer...........
Saw Anywhere!
