Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: My Stihl 029 problem  (Read 2623 times)
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« on: October 07, 2003, 09:00:43 am »
 I have an 029 farm boss with 20" bar. I bought it new 3 years ago and have used it quite a bit. It has developed a problem. When it gets warm it will stall out. It cuts very good when it is into a log but when limbing or after a cut it will stall out when you pull the trigger.
I have changed the air filter twice it seemed to help for a little while. Installed new spark plug, put in new gas line filter and adjusted the high and low mix screws. I took it back to the shop where I bought it and they just called and said there is no problem.
Any Ideas?
If I cannot repair the problem I am going for a new saw. Any suggestions on a better medium sized (20") Stihl?
WS
Imagine, Me a Tree Farmer.
Jon, Appalatian American Wannabe.
Offline Kevin
    • The Milling Masters
Re: My Stihl 029 problem
« Reply #1 on: October 07, 2003, 10:14:33 am »
What test did they perform on it?
Is the plug wet or dry when it stalls out?
Offline Jim_Wahl
  • I am from Iowa, but I seem fine.
« Reply #2 on: October 07, 2003, 01:19:32 pm »
Be sure to check and see if the spark arrestor is plugged up.
'The problem with quotes on the internet is you can't confirm their validity.'  -Abraham Lincoln
« Reply #3 on: October 07, 2003, 01:20:09 pm »
Kevin,
I am going to pick it up tonight, I'll run it and check the plug when it dies and post later tonight.
Jim, I'll check that too.
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
« Reply #4 on: October 07, 2003, 05:14:02 pm »
If this isn't an ignition problem, remove the carburetor and remove the cover on the pump side, the side that has a more convoluted appearance.  Look for a pasageway that is about 3/8 inch diameter.  This pasageway has a fine mesh screen in it to collect any crud that made it through the filter before it clogs some smaller pasageways beyond.  Look for a collection of small fibers plugging this screen.  If it gets bad enough, the saw will stall out in the cut as it can't get fuel fast enough.  I use the point of my pocket knife to scrape the crud off the screen and I'm back in business.
« Reply #5 on: October 07, 2003, 06:25:10 pm »
ok, I was running it some tonight and here are some more simptoms. After warming up it will run wide open fine, cut a log fine, but if alowed to idle for about 10 seconds it stalls, as it stalls sometimes you can pull the triger and bring it back and other times it stalls out. When limbing after a cut when you go to pull the trigger for the next cut it sometimes stalls out.
It's a fairly new plug. I pulled it after it stalled and it was dry, and the anode was light on one side and dark on the other.  Gap was 20 and I enlarged it to 25 and it seemed to run better but I ran out of light and did not get a good test in.
This is a strange one.
Offline Kevin
« Reply #6 on: October 07, 2003, 07:22:05 pm »
I'm guessing here but with a saw that new the seals or gaskets shouldn't be leaking but you never know without pressure testing.
Things to check for would be tank vent,restricted fuel line or dirty filter, proper jet settings, maybe loose body screws on the carb.
Do you store fuel in the saw for long periods?
« Reply #7 on: October 07, 2003, 07:22:20 pm »
Hmmm.... It still sounds like carburetor, but now it sounds more like a leaky float valve.  Take the carburetor off the saw and remove the plate over the float diaphram.  Remove the diaphram, being sure to unhook the pin from the valve arm.  Carefully remove the screw holding the valve arm and watch where the spring flies off to. (it's better to hold the spring with your finger, but I rarely remember to do that)  Remove the valve needle and wipe the tip with a soft cloth, making sure you leave no lint on the tip.  Put it back together and put the carb back on the saw.  Try running it.  Report back here.  :o
Offline Kevin
« Reply #8 on: October 07, 2003, 07:32:43 pm »
Your plug should be .020".
Offline ladylake
« Reply #9 on: October 08, 2003, 03:22:41 am »
Sounds more like a dirty carb. When you have it out clean all the passages. Take both high and low needles out and blow air through the holes. If it was flooding due to a leaky needle it would be smoking a lot when you opened up the throttle. Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
« Reply #10 on: October 08, 2003, 11:10:42 am »
I'm thinking carb also. This chainsaw gets used quite a bit so fuel should not be a problem. I don't store fuel long either, just dump it in the truck and mix up some fresh stuff.
I am going to try one new spark plug, caus it is easy, then pull the carb. can you walk me through re adjusting it after i get it back in?
Should I pick up new gaskets before I get started?
Jon
Offline Kevin
« Reply #11 on: October 08, 2003, 02:25:11 pm »
Jon ;
Try cleaning the carb on the saw first.
If that doesn't work carb rebuild kits are relatively inexpensive.
We can get you readjusted but you should get  someone to do the final test with a tach if you don't have one.
« Reply #12 on: October 09, 2003, 11:17:04 am »
Well, suffered a slight setback last night.
I pulled the carb and took the bottom off and there was some crud in there, not much but mabe enough. I put the air sprayer on the compressor, (Let me interject here that I almost always remember to drop the regulator down to 40 psi while doing small work... almost always) and promptly blew the carb bottom, gasket and diaphram across the barn at 120 psi. I did find the bottom but gasket and diaphram are nowhere to be found.
I went out at lunch and ordered a rebuild kit from my local supplyer. They had a good laugh at my misfortune. One old guy in the back said "Yup, that'l happen".
Kevin, tell me more about the tach, is it specific to Stihl or would an automotive one work, and how would you connect it?
Offline Kevin
« Reply #13 on: October 09, 2003, 11:28:15 am »
I have the A model and it works well on all my saws...
http://www.madsens1.com/tach.htm
« Reply #14 on: October 09, 2003, 02:05:26 pm »
I'm heading down to Colonial Beach VA to do a decking job this weekend. I'll get back to you all on monday with the continuing saga of how not to fix an 029
I did just order the B model Tach ;D
Offline SasquatchMan
  • Get it done.
« Reply #15 on: October 10, 2003, 06:48:17 pm »
WS  I assume you'll get your 290 running again, but if not, and you want a "better" Stihl, then you need to get into the "even numbered" saws... the 340 would be the "pro" equivalent of the 290, and the 360 is bigger than that...  The 310 and 390 are just big-bore versions of the 290, and quality in this series of saws is not the same as the pro saws.  The 290 is decent, (it better be, I just bought one), but it's not of the same ilk as the pro saws.
Senior Member?  That's funny.
« Reply #16 on: October 13, 2003, 05:32:13 pm »
Yeeee Haaaa, were back in action.
I picked up the rebuilder kit and installed it this evening. Was able to cut about 1/4 cord with no problems. 8) 8) 8)
Found:
Fine grit in the bottom of the carb.
Original needle valve had a rubber? tip which was dirty and indented. New one is all metal.
Diaphram had grit on top of it.
I should be receiving my tach any day now. Then I want to  dial it in.
Thanks for all the help guys.  :) :)
WS
Offline Gus
« Reply #17 on: October 13, 2003, 09:43:14 pm »
WS,
I love it when things come together. Wonderful!!! 8)
"How do I know what I think unless I have seen what I say?"
Offline jokers
  • Chainsaw Freak
« Reply #18 on: October 14, 2003, 03:08:15 am »
Hi Weekend Sawyer
I hope that you flushed your fuel tank and checked the filter and pick up hose in the tank if you found grit in your carb. I`d flush my gas cans also because something is amiss, first by introducing the grit to your fuel tank and second by the fact that it made it to your carb. How much do you suppose made it to the wear surfaces of your piston/cylinder and rings?
Russ
« Reply #19 on: October 14, 2003, 11:17:57 am »
Hi Russ,
Good advce. When I started having this problem I did change the tank filter and flushed it. I also changed out the air filter and put in a new plug.
When the gas gets a little old I put it in my truck, as suggested by someone here, truck does not mind at all!
WS
Saw Anywhere!
