Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: What is "shovel logging"?  (Read 4181 times)
Offline Jasperfield
« on: February 08, 2010, 08:37:54 pm »
Just exactly what is "shovel logging"? I've seen it mentioned occasionally but don't know what it is.
How is it different from other Eastern US methods of logging, and does shovel logging use specialized equipment?
Here in WNC, I've never heard the term.
Jasperfield
Offline Meadows Miller
  • The Walkabout Sawyer
Re: What is "shovel logging"?
« Reply #1 on: February 08, 2010, 08:43:54 pm »
Gday
Jasper Its when you use an excavator (shovel) with a grapple  to pick up the logs within reach  and throw it progresevly towards the landing it gets used in wet and steep country and by blokes who only have one bit of gear  ;) :D ;D ;D 8) 8)
Regards Chris
Meadows #2 delux manual circular sawmill & Edger, 1997 mod 8-20 & 2010 mod 10-30 Lucas Mills ,Homemade 44" circular table top sawmill , Chamberlain 80hp tractor loader and farmi winch. 9 ton payload  79 mod International Acco 24' traytruck , 350. 359. 372  Huskys and a couple of 2095 Jonys
Offline SwampDonkey
  • Large Tooth
« Reply #2 on: February 08, 2010, 08:44:55 pm »
In BC, it's also called "Hoe Chucking" where logs are chucked roadside by excavator.
http://web.cocc.edu/logging/szlinks/shovellog.htm
Dirty Harry
Offline Jasperfield
« Reply #3 on: February 08, 2010, 08:49:16 pm »
OK, thanks.
I guess I do know what it is, just didn't recognize the operation by the name.
Thanks,
Jasperfield
Offline barbender
« Reply #4 on: February 08, 2010, 10:32:40 pm »
Is this method just used to move wood short distances, or do they take care of long skids this way too? The reason I ask is that I was reading a western logging publication, and the shovel loggers said they had replaced all of their skidders because this way is cheaper. Just trying to get a better understanding of how this works.
I just want to run my mill
Offline WDH
  • April 1998 - August 2008
« Reply #5 on: February 08, 2010, 11:47:26 pm »
In the US South, shovel logging is generally used where it is very wet.  The shovel loader "shovels" the wood to a shovel road that is laid down using logs so the skidders can access the wood.  As the operation finishes, the shovel loader picks up the shovel road logs as they work their way back to the landing.  The Discovery Channel has a show where shovel logging is used.  It is called "Swamp Loggers" and is set in Eastern North Carolina.  It airs on Friday nights at 10:00 p.m. (Eastern time).
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline captain_crunch
« Reply #6 on: February 09, 2010, 12:36:19 am »
Shovel logging is about the Quickest and cheapest way to log there is. Shovels set up for this have additional armorment and Grouser Pads rather than street pads like on loading shovels. And it will Mortify you where they will get them things while doing this
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: February 09, 2010, 06:59:08 am »
Where we setup a shovel logging show on a cut block was always on wet terrain and it was either a part of the block or a small block to begin with. The wood was usually poor in there.
Dirty Harry
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #8 on: February 09, 2010, 07:02:00 am »
I would have to strongly disagree with that statement as a blanket statement unless you qualified it with the conditions and terrain the geographical areas the logging is taking place. No way is shovel logging quicker nor cheaper on flat level solid ground then a conventional skidding operation.
Because inquiring minds want to know... ;D Expired Circle Sawyer-Automatic Commercial Mill-Since 1979
Offline SwampDonkey
  • Large Tooth
« Reply #9 on: February 09, 2010, 07:33:09 am »
In my scenario it was always considered the cheapest set up because of the quality of the wood and the small size of the area it was applied. It wasn't always steep ground, but it was usually sensitive ground, where the "side hill gougers" or known as the grapple yarder were not allowed to yard.
Supersnorkel/grapple video. Supersnorkel is a loader with log extensions for further reach.
Dirty Harry
Offline stonebroke
« Reply #10 on: February 09, 2010, 10:16:48 am »
They sure like to cut high stumps out there.
Stonebroke
Offline SwampDonkey
  • Large Tooth
« Reply #11 on: February 09, 2010, 10:25:56 am »
Those high ones along the road are for anchoring the machines when yarding and possibly help stabilize the road. Sometimes a support tree is standing as well to help in the yarding where deflection isn't that great from poor road location (no deflection lines run to profile the hillside).
Dirty Harry
Online Paul_H
« Reply #12 on: February 09, 2010, 10:27:56 am »
The stumps aren't normally cut that high.What would have happened was the road right away was fell first and as the road was built,the wood,stumps and some over burden was piled on the bottom side against the trees in some places.If the right away wood wasn't loaded out before the setting was fell,then the fallers have no choice but to leave some high stumps.
Guyline stumps don't need to be high,usually you dig down on them to get the notch as low as possible.
and we shiver when the cold wind blows
Offline stonebroke
« Reply #13 on: February 09, 2010, 10:31:05 am »
Aha, Would it not pay to go back after the logs are removed and cut them down?
They look like they would be a pain to work around with those machines.
Stonebroke
Online Paul_H
« Reply #14 on: February 09, 2010, 10:38:24 am »
They could cut them off but where they are doesn't interfere with the yarding because of the height of the machines,or "lift". Having a few good stumps to pile the logs against on a steep sidehill is handy sometimes too.
Offline SwampDonkey
  • Large Tooth
« Reply #15 on: February 09, 2010, 10:38:49 am »
Google "grapple yarder supersnorkel handbook"
It'll be the first hit, pretty good reading. ;)
Dirty Harry
Offline thecfarm
« Reply #16 on: February 09, 2010, 08:03:38 pm »
Not a term that is used around here either.I get a free monthly magazine called Timberline.Keeps me up to date on some of the equipment. Axman and swamp logging showed it too.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline barbender
« Reply #17 on: February 10, 2010, 11:05:59 am »
If it was always quicker and cheaper I think people would use it around here too. So it must be a special application. I'd like to see that swamp logging show, I saw the previews and it looked pretty interesting.
Offline Ron Scott
    • Ron Scotts Web
« Reply #18 on: February 10, 2010, 11:24:03 am »
~Ron
Offline SwampDonkey
  • Large Tooth
« Reply #19 on: February 10, 2010, 11:30:03 am »
Ron's link references the same information page as mine above. I think if you was to explore the BC Ministry of Forests and Range or Work Safe BC websites they would have a detailed explanation of Shovel Logging/Hoe Chucking.
"Silvicultural Systems Handbook for British Columbia"  has a piece in there about it.
Dirty Harry
Saw Anywhere!
