BID ON A FORUM AUCTION!
the 362 is diffinately a few onces heavier,but it does have more power&torque,and will burn less fuel. these are proven facts,both on paper , and in real world useage.
Quote from: STIHLFULLSKIP on February 10, 2010, 08:14:49 amthe 362 is diffinately a few onces heavier,but it does have more power&torque,and will burn less fuel. these are proven facts,both on paper , and in real world useage.Real world? Paper? Did you all flunk math or something? Since when is a dozen the same as a few? We are talking 3/4 of a pound here, not a few ounces. Wake up class, 12 is not a few, and 3/4 of a pound is not equivalent to a few ounces. Also some corrections here: the 362 has more power only compared to the USA model 361. It has the exact same power as the EU/UK model 361. If you compare the power to weight ratio, the 361 is better. Stihl compensated for the added weight of the 362 with a tad more power, like they compensated for the 441. Its a gimmik to get you guys all suckered into thinking that its a souped up 361, which it is not. Its an EPA mandated saw model. Otherwise they would have never re-designed the 361, or the 440 for that matter. Also the Stihl ads are misleading about the fuel consumption. Thay claim that the 362 is more fuel efficient than 'previous model saws'. Case in point, they do not compare the 362 directly to the 361 fuel consumption. More gimmicks that you guys are falling for. Where 'on paper' does it say that the 362 is more fuel efficient than the 361? So lets compare the facts please, and not the BS?
Geeze it's only a chainsaw not your first born
In another thread, I remember windthown saying he had tendonitis, so he liked lighter saws. I have something, don't know for sure what it is, that heavier saws hurt my wrists. Ten and twelve years ago I ran 66s and 394s, but have been going to smaller saws ever since. I wouldn't want to go any smaller than the 361, though. For some of us older guys--speaking only for myself here, wouldn't want to use the "O" word to describe anyone else--that 3/4 pound difference between the 361 and 362 is substantial.What I've found is that my production has dropped very little if any. The bigger saws cut faster, but it only makes much difference in a big cut. So you're not gaining any time when you're walking between cuts, limbing, or lopping. I estimated once that on the kind of trees I cut, mostly hardwoods, I might save a couple of minutes in a two foot diamter tree that takes me a half hour or so from start to finish. (These are trees with a fair amount of eight foot firewood in the limbs. That's why they take that long.) But then I might gain using the smaller saw by needing fewer sit-down breaks.I have not run a 362, so can't comment directly on that. I owned a 441 for three days, and it wasn't a bad saw, but it hurt my wrists, so I sold it and took a $200 loss. I didn't listen to the significant owner complaints...had to try it for myself, and look what happened. That's why I stayed away from the 362; had too many similarities to the 440/441 situation.As to the 361's air cleaning...no, I don't like blowing out the filter every day, that's why I have an extra filter. Then it's cleaning every other day.
I usually run a 441 or a 372 for bucking logs, we cut mainly hardwood. Would a 362 keep up with a 441. We bucked up 8500ft this afternoon in 2 hours and I was thinking a lighter saw would be nice. Most of the hard maple we bucked was 30-32" across at the base and 20" about 30-35' feet up the tree. I run full skip chains on all my saws, makes sharpening faster and keeps the rpm's up.
You would need to fully woods port a 360/361/362 to keep up. You would also have to modify the oil pump in the 361 (or 362) to run a 28 inch or larger bar. The 361 has the same oil pump body as the 460, and you can replace the guts of the pump with the 460R parts and it will gush oil.
