Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Chain saw coil cleaning  (Read 838 times)
Offline GlenM
« on: February 01, 2010, 04:20:07 pm »
Have several saws to tear down and do some R & R.
Would it hurt to clean the coil by spraying copious amounts of brake cleaner on them??
thanks,
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
Re: Chain saw coil cleaning
« Reply #1 on: February 01, 2010, 04:32:21 pm »
We clean them by removing the covers and the clutch drum, soaking them with a degreasing detergent, then spraying them with a pressure washer. We've been doing that for 20+ years - no problems - nice to work on afterwards....
cheers
John
Offline GlenM
« Reply #2 on: February 01, 2010, 04:53:55 pm »
Thanks for prompt reply.
I just got through with removing a coil, used a plastic bristled parts brush to remove as much grime as I could, sprayed it with brake parts cleaner and blew dry.  Looks brand new.
I had thought about using your method for total saw cleaning.  I think if I plugged muff and carb (like doing a pressure test), I could run it through a car wash, but, I'm gonna use your method next.  Luckily, I have a total junk unit I can try it on.
Thanks,
g
Offline GlenM
« Reply #3 on: February 02, 2010, 11:49:47 am »
Took an old plastic Poulan 2150. plugged muff and carb, poured a little bit of old gas into the engine well, sprayed with engine degreaser, let unit sit for 5-10 mins.
Then used my air compressor siphon pressure washer and sprayed hot soapy water over all of the unit, twice.
Then blew dried best I could.
Don't look brand new, but can disassemble on kitchen table now, wife shouldn't mind, no greasy grime.
 Thanks,
Offline stonebroke
« Reply #4 on: February 02, 2010, 01:26:40 pm »
Your wife lets you work on chainsaws on the kitchen table?
Stonebroke
Offline GlenM
« Reply #5 on: February 02, 2010, 02:26:36 pm »
Well,
Perhaps I exaggerated  :D
Online beenthere
  • EIEIO
« Reply #6 on: February 02, 2010, 04:31:28 pm »
Stonebroke
Only if I run it through the dishwasher first.  ;D
Offline stonebroke
« Reply #7 on: February 02, 2010, 05:24:36 pm »
 :D :D :D :D :D :D :D :D :D
Stonebroke
Offline JohnG28
« Reply #8 on: February 02, 2010, 07:31:26 pm »
I get flack just for putting saws in the laundry room in the basement, I think the kitchen table would push her right over the edge
Offline timber tramp
« Reply #9 on: February 03, 2010, 01:45:02 am »
Stonebroke
   Yep!             :) TT
Cause every good story needs a villan!
Saw Anywhere!
