Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Self Adhesive Wood  (Read 565 times)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Self Adhesive Wood
« on: October 05, 2003, 09:26:03 am »
  Went outside this AM and ripped some 2 X 6's for the drum sander project. First real work I done since the "incident". Man, I'm bushed.
 Ennyhoo, After sawin them boards and cutting to length, here is what I have. Self stick lumber. This ain't even "Fat" wood.
Y'all just THINK ya got sappy wood.
 Here's a pic of the Sanding Drum. 40" long X 5" dia.
Offline Paul_H
Re:  Self Adhesive Wood
« Reply #1 on: October 05, 2003, 09:41:36 am »
Harold,
where did you find the drum? I checked with a local rental shop and asked about a drum from an old floor sander.He showed me a Aluminum drum with rubber fins,around 6" dia. x 12-16".(?)
$900 cdn new,he would give me the used one for $500  :-X
and we shiver when the cold wind blows
« Reply #2 on: October 05, 2003, 09:52:57 am »
 Din'tcha know we have a welding-machine shop???
 We couldn't even make plans if we couldn't build the parts ::) ;D
Offline woodmills1
  • the truth shall set you free
« Reply #3 on: October 05, 2003, 10:01:55 am »
soak that blade in lestoil and I bet the pitch comes right off.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline Paul_H
« Reply #4 on: October 05, 2003, 10:09:43 am »
I fergot about the machine shop :-/
Next stupid question  ;D What holds the paper or grit to the drum?
I really don't know
« Reply #5 on: October 05, 2003, 10:17:45 am »
  Some of that "PINE FAT" ::) ::) ;D ;D
 Actually, (I ain't done this yet) I figger on laying out the 10" wide cloth back paper, so we can put a couple screws into the END of the roller, to hold the end of the paper. Then wrap it, spiraled, all the way across and slot the paper, so it can move a little as it works, and then snug up the tail end with screws, on the other END???
 Getting the paper wrapped the correct way, will cause it to "strangle" itself on the drum. I also have sanding disk glue, that ya use for sticking disks on flat sander plates, on a electric motor shaft. A lil of that can't hurt, I don't think.
 Paul, how long a drum do ya need???
Offline Kevin_H.
  • my two boys
« Reply #6 on: October 05, 2003, 03:26:59 pm »
Not to stray from the thread, but we use oven cleaner on our blades, cleans them right up.
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
« Reply #7 on: October 05, 2003, 03:34:49 pm »
  Kerosene, Gasoline, WD-40, Pam, among some of the things we use, whichever is handiest.
Offline Paul_H
« Reply #8 on: October 05, 2003, 03:45:20 pm »
Harold,
I was thinking of having the sander attached to the back end of the planer.It should be at least 13" long(wide)
« Reply #9 on: October 05, 2003, 04:21:18 pm »
  Ain't we been through this before??? ;D
After extending the table, I see no problem putting a drum after the Planer.
 My original plans called for making the drum with a 1" all thread and several hardwood discs. Thread 'em on and glue 'em up. Then, when ya get the rest of the sander built, run the drum while holding a stick with sandpaper on it, against the OUTPUT under side of the drum. That will true it up and then seal it with Urethane.
 Some sort of "feeler" will be required, to allow the drum to just hit the surface, without "grabbing" and tearing the paper off the drum.
 You will have to "sync" both feeds or you will have a dip, when the board leaves the planer and the extra feed takes over.
Saw Anywhere!
