BID ON A FORUM AUCTION!
Pouring bar oil out of a gallon jug is simplified if you do not tear off the entire foil seal under the cap. Instead, try cutting a vertical slice in it using a screwdriver or pocketknife. Only make it wide enough to pour without slopping all over the place. An old timer showed me this trick about 10 years ago. (Image hidden from quote, click to view.)
Got a chance to play with my new 520 , got the limit caps off threw in the bush
Just remember that when you do a muffler mod, the warranty is gone.
Then your dealer will look at it and tell you to buy a new one because it will cost too much to fix the old one.
A dealer near me said they are completely made in the USA except the motor. It is made by the biggest small engine 2 stroke company in the world. Is this true? It came from a Stihl/ Echo dealer.
