BID ON A FORUM AUCTION!
Also have found another product called the Wood Minder. It is a monitor for outdoor wood boilers. It reads your boiler temp and roughly how much is left in the firebox from inside the house. Has anyone use a product like this with e classis.
I agree with Ken999 use the larger pipe. You can get more btu's thru a larger pipe with less friction loss, [and use a smaller pump]. You may be able to use a taco 008 or 0010 compared to a 0012 and the smaller pump will use less electricity. A 1" pipe will carry 90,000 btu's with a 007 pump a 11/4" pipe will carry 140,000 btu's with a 007 pump. Holmes
