Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: More on Ethanol  (Read 1463 times)
Offline DonT
Re: More on Ethanol
« Reply #20 on: January 28, 2010, 07:34:02 am »
Not looking to Hijack this thread,but can someone explain what sea foam is?And the benefits of using it?   Thanks
Offline Stutz
Re: More on Ethanol
« Reply #21 on: January 28, 2010, 08:54:59 am »
Safely frees sticky lifters and piston rings, removes carbon build-up and oil residue, reduces pinging and rough idle. For Carbureted or Fuel Injected Gasoline Engines - Autos – Trucks – Tractors – Motorcycles – Marine – Small Engines – Industrial Engines Great for Diesel Engines Too!
sf-lg-motortreatment_productSEA FOAM Motor Treatment is a 100% pure petroleum product that safely and effectively cleans internal fuel and oil system components, helping your gasoline or diesel engine run cleaner and more efficiently.  SEA FOAM is an EPA-registered product, and will not harm engine components, seals, gaskets, catalytic converters or oxygen sensors.
Added to motor oil -
SEA FOAM liquefies gum and varnish deposits or internal engine contaminents, removing carbon deposits, freeing sticky valve lifters and rings curing rough idle, pinging and hesitation problems.
Added to gas -
As a fuel system additive, Sea Foam will clean fuel injectors, clean carbon, gum and varnish deposits, add lubricity to fuel, stabilize fuel for 2 years and control moisture.
As an oil system additive, Sea Foam controls moisture, gum, varnish and residue deposits.
Offline bandmiller2
Re: More on Ethanol
« Reply #22 on: January 28, 2010, 04:17:20 pm »
Ole Stutz pretty much hammered it Sea foam is a product that works.I bought an old mill with a ford 6 cyl diesel power unit that has lain fallow for many years.Got it started but had a skip dosed it good with sea foam.Next day I was planning to pull the injector to check it started the engine to pinpoint the offending injector no skip.Frank C.
Offline stonebroke
Re: More on Ethanol
« Reply #23 on: January 28, 2010, 04:34:22 pm »
Sea Foam is great stuff.
Stonebroke
Saw Anywhere!
