Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: what you think is a better saw husky 346xp or stihl ms 260 pro  (Read 9465 times)
Offline 567paloggger
« on: January 16, 2010, 05:13:52 pm »
guys what do you think is a better saw the 346xp or the 260 pro almost the same saw but the 346 i believe is a little lighter whats your opinion on them
Offline Rocky_J
Re: what you think is a better saw husky 346xp or stihl ms 260 pro
« Reply #1 on: January 16, 2010, 06:42:19 pm »
Not even close, the 346 by a mile. The 346 is the best in class and the 260 is probably Stihl's worst pro model saw as far as power to weight. The 260 was ok 10-15 years ago but it is an old and tired model that can't hold a candle to the current top 50cc saws.
The last Stihl 260 I owned was one of their infamous fixed jet models where they decided that users no longer needed to be able to tune the carbs. That move ended up with my 260 getting flung from a tree at about 40' and I went many years without ever touching another Stihl because of that piece of junk. Thankfully Stihl gave up on that awful tactic on the pro saw models and went back to adjustable carbs (after you trim the limiter caps).
Offline Cut4fun
« Reply #2 on: January 16, 2010, 07:05:24 pm »
The 260 is lighter, but the NE 50cc 346xp is light years ahead in the cut.
Learn Chainsaw Repair ChainsawRepair
Offline ladylake
« Reply #3 on: January 16, 2010, 08:03:57 pm »
 Seems like on the ither forum at the GTG  the MS260 was about 1 second behind the 346xp and the Dolmar 5100 in a 10 second cut and almost 1# lighter. Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline des170stihl
« Reply #4 on: January 16, 2010, 09:57:55 pm »
I,m kind of partial to the STIHL stuff since I own a 260. I,ve lost a lot of faith in the Husky co. since they sold out to the Vacuum Cleaner Co. called Electrolux Co. I guess they both would work allright when they are brand new. But which one will be worth more when they are 5 years old ???
STIHL MS170* STIHL MS260 Pro* STIHL MS 230* ECHO CS 341* Husky 339 XP * Wallenstein 20 Ton Splitter* Massey Ferguson 1528 w/Grapple ( Skidder Wanna Be ).
Offline windthrown
  • Never give a inch!!!
« Reply #5 on: January 17, 2010, 12:29:45 am »
First off, which 346xp are you talking about? There are two of them. One is 45cc, the ther is 50cc. I do not know why Husky has multiple saw engine sizes with the same model numbers (not just the 346). Stihl has a slightly larger P&C on their later model 260; a 44.7 mm (new) vs. 44.0 mm (old), but the the 026 and 260 are all 50cc class saws. The Husky has more plastic, the Stihl has older technogy. The Husky also has an outboard clutch. I hate outboard clutches. I can flip from an 8 pin .325 rim to a 7 pin 3/8 rim on my 026s in about a half a minute. Also the new 346 has a cat in the muffler for EPA. Stihl is changing the 260 into a 261, but it will be one of the last saws they convert to 2010 requirements. The 260 is still around becasue it is one of the most popular saws that they have. Stihl planned on phasing it out years ago, but high volume sales kept them from scrapping them (the 270 was developed to replace it, but it is heavier and never caught on, similar to the 280).
Personally I love my 026s. I have 4 of them. If you want to toss them from trees, toss them my way. These are great little saws. They take a muffler mod well, and they are really easy to port and get a whopping gain in power. If you are going to run *ANY* saw with a fixed H jet carb? Well, you are going to have a POS saw, regardless of brand. You cannot run them richer so you cannot tune them properly or modify them. $35 will get you a brand new Walbro WT-194 with fully adjustible H&L jets. That is the best carb to run on an 026 or a 260. But do not blame a good saw (or a complete brand) becasue one had a fixed jet carb!
I ran a woods ported 50cc 346xp last summer and that thing screamed. It got me into woods porting my 026s and bringing out the real power in them.
I ship Stihl saws down under and to north Europe... message me for details.
Offline cb6048
« Reply #6 on: January 20, 2010, 05:51:17 am »
I'm always raving about my 346xp.....my favorite
when hell freezes over I'll snowmobile there too
« Reply #7 on: January 20, 2010, 09:09:52 am »
i have a 346xp 46cc saw idk how the new ones are since they changed them just was wondering how the 260 pro compaired to the husky since im in the process of converting over to stihl when the huskys fully die then ill replace them with stihls
Offline windthrown
« Reply #8 on: January 20, 2010, 06:08:29 pm »
Well, you had better replace your saws soon, as Stihl is phasing out all their line of saws with the new strato-version engines now. The 260 will be one of the last saws converted to the 261 but converted they will be. Probably by the end of 2010. Stihl has already dropped the 260 non-PRO version. They are just as professional as the PRO version though. Only diff is the adjustible oiler, and the decomp button on the PRO model. The non-PRO model oils a 20 inch bar just fine, and the decomp is not needed on a small saw like this one (especially if you drop start your saws). A light frame woman like my ex might want/need the decomp button on the 260 though. The 261 will be heavier... and have a strato (air injected) engine as well as a bolt on air filter cover and centrifugal (Husky style) air cleaner. They will also be more expensive than the 260 is now.
Offline jumpinmp
« Reply #9 on: April 11, 2010, 06:28:01 am »
If it was my money, I would go with the 346xp.  I have a 2 old fart loggers as customers that run a 24" bar with 3/8 chain on their 346xp (not that I would recommend that...).  They let the younger guys carry around the "heavy saws".   :D
Offline STIHLFULLSKIP
« Reply #10 on: April 11, 2010, 04:40:37 pm »
the 260pro my be an old design,but it is a good one.  it is lighter than the husky,and w/a 5min. muff. mod it will run with it too. a 260 will last you 20+ yrs. if cared for. a husky running @ 14,700 will be dead in 4 or 5yrs. they are heavier,they have a 1970's tiny,outboard clutch,and the quality of huskys' plastic is horrible. who is gonna notice a second or two in a cut. i run a 260pro,MM,.325/16" full comp,w/8pin driver, and it will run with and comparable 346.  i am not trying to start a bash fest here,just stating my opinion. the 261 will be available here in late may,it will be 1lb. heavier,it will have 3.8hp,it will be strato,and it will be expensive.
Offline Al_Smith
« Reply #11 on: April 11, 2010, 05:37:21 pm »
I won't pick sides but will point out something regarding these two saws .
There is a thread going as I type on two different forums featuring the 346 Husky which is getting reworked . If you know anything about engines designs and saw how that model is ported it becomes plain as day why they run so good .
The thing has very large double tunneled transfers which in itself is superior  to the single tunnel design of Stihl with regards to moving air . With no windows in the piston ,it's a bottom feed stuffer which kind of raises the pressure just a tad bit  on the transfer cycle . It's a well thought out design,I like it .
Eventually I'll run across one fairly cheap and own one myself to be converted into a 3 cubic inch cookie cutter . Heaven only knows I don't need anymore larger saws . :D
Offline peppone
    • la motosega ed altri attrezzi da taglio
« Reply #12 on: April 11, 2010, 06:02:07 pm »
346xp. ms 260 is not so good, probably one of the worst professional saws by stihl. anyway ther's another 50cc I consider better than 346xp: dolmar ps5000. from my point of wiev it's the best 50cc chainsaw...
saluti
peppone
you're invited to visit my forum all about chainsaws:
http://lamotosega.forumattivo.com/forum.htm
saluti
peppone
Offline windthrown
« Reply #13 on: April 11, 2010, 08:11:33 pm »
I have four 026s, and the newest one is 6 years old (and it has a new 260 engine in it). The oldest is over 20 years old. They run and run and run. Thye are fun saws to run too. Nice and light and nimble. I would not rate it the worst Stihl saw by far. The worst pro Stihl saw? Maybe, but its the cheapest, the smallest, and the one with the most plastic of the Stihl pro line.
I dunno about the Dolmar 5100s. I was not impressed. 346xp impressed me the most of the three when we ran them at a GTG last year. Then there was this fully ported 346xp. That thing SCREAMED! Had almost the same power of a stock 361. If it were not for that outboard clutch, I would own one now. I hate outboard clutches. To the point that I got rid of all my saws with outie clutches.
Offline Rocky_J
« Reply #14 on: April 11, 2010, 08:22:17 pm »
The outboard clutch is only a big deal if you constantly throw chains.  ;D
I dumped my last 026 Pro for a 346 with the outboard clutch in order to escape the outrageous proprietary parts costs and the horrendous fixed jet carbs they were using at the time. Stihl finally got smart and gave up the fixed jet carbs but by then it was too late for me. I was unwilling to go back to a saw with the same weight, higher cost and half the power. My oldest 346 is now about 8 years old and is still my 'go to' limbing and smaller bucking saw.
Offline SawTroll
« Reply #15 on: April 12, 2010, 02:29:39 pm »
saluti
peppone
LOL - for handling in the woods the PS5000 feels like a brick compared to a sabre (346xp)..... :D :D :)
My 5100S was "demoted" to yard use/bucking only several years ago, after comparing them in the woods.
Firewood saws: Jonsereds Raket 621 (1970), Husky 353G, Stihl MS361W, Husky 372xpg, New Edition Husky 339xp, Dolmar PS5100SH, New Edition Husky 346xpg, Jonsered 2153WH, Husky 560xpg.
Offline SawTroll
« Reply #16 on: April 12, 2010, 02:38:21 pm »
I don't understand that people still ask this question - the debate really was over a long time ago.  ;)
The original 346xp was out in 1999, and the debate really was over a few years after that - later the gap between the two models have opened up considerably........ 8) 8)
Offline Rocky_J
« Reply #17 on: April 12, 2010, 10:40:04 pm »
I'm not big into saw racing, more into work production, but here's a little saw p0rn with an old style 346.  8)
Offline downeast
« Reply #18 on: April 15, 2010, 07:44:11 am »
A story from the trenches.....a dreaded "homeowner". (Why so-called "pros" need to throw this out is beyond us. :o)
Been harvesting, cutting, scrounching, clearing for firewood and enjoyment for years before retiring on this 60a woodlot here. Mostly using a Husky 137 for climbing, a Stihl 028 and a Stihl 044 for ground work and felling. With age and past injuries ( mil and sports from former- repeat, former-- brainless macho days) , I needed a smaller, lighter saw. After a close call with the 044 in brush and no protection yielding only 8 stitches above the patella ( note to fellow dumbos: don't cut without PPE, Forest Gump time ) it was time to learn how to use the most dangerous tool made correctly: to cut efficient, safe, fast. I took both the CLP and Game of Logging programs. Incredible learning experience, better than grad school or AIT or Camp Elgin or having kids.
Which saw ? It had to reliable, torguey, familiar, carb adjustable.....and light. Many users of the 346XP said they loved it....cured baldness it was and is said. BUTT: reports of reliability and "fussiness" in the cut were concerns. Tools for filter cleaning and caps were another downside. One local logger using it for limbing said that he had to replace it every year. Others, "pros" BTW, liked the MS 260/026 for light use for them.....it ran and ran for years without problems. For us, what's a second in comp cutting anyhow ?
Choice was the MS260 that is now the go-to saw for everything. Even used a 20" bar on it for some oak noodling; not so hot, it bogs when buried --expected. For the past 7 years the 260 has performed. Work: T.S.I., plenty of softwood blowdowns, 6-8 cords of firewood, pulp when the market is up. NO problems other than B&C replacements 1x-2x/year, sprockets, filters, plugs. All the harvesting is done in out winter only. Starts when cold, when hot, in snow, in mud. And those wondous "flippy caps"--use 'em correctly, never a problem. Can be used with mittens (no concern for you in the banana belt. Everywhere is south of here.) I have yet to read or hear about a 346XP used hard for more than a few years. Users speak up ?
Old design, sure. Sexy, no. I don't want that in the woodlands here. I got old reliable. Too bad Stihl is RIFing it.  :(
Offline Rocky_J
« Reply #19 on: April 15, 2010, 09:17:13 am »
I posted it in another thread here, but my very first 346 is now 8 years old and still running strong. It was ported when new, before I even took delivery, and was strong enough to snap a couple clutch springs in the first three years of use due to the abundant torque. Here's a couple short videos I took about a month ago. Remember, this saw has been used commercially for 8 years, not just on weekends but all week long.
Saw Anywhere!
