Howdy all,
I've got a sunhill import open end 15" wide belt sander. Works wonders over the old 24" twin drum i had, but the feed motor quit on me and i'm not sure where the weak link might be. Its a three phase machine i run off converter and the main motor powers up so my connections to there are fine (main sanding motor on sander) The feed motor is single phase and when i push the button on the outside i see the contactor engage inside the control panel and a little arc on one side of it, but not the other. Is this contactor a weak link? I've jiggeled every wire going in and out with no luck. Where to look.
Another question the panel says "for single phase motor wire here.. for 3 phase wire here..." I'd like to switch this motor out with a single phase but thought the wiring would have to be redone inside. This machine comes in both single and 3 phase. Think i can just switch over and not have to change anything else inside?
Any ideas where to check, what to check would be helpful.
kelvin
