BID ON A FORUM AUCTION!
So what are you going to do when the power goes out, run a generater to run your pellet stove??
So what are you going to do when the power goes out, run a generater to run your pellet stove?? I guess the power dosen't go out where you live. I'd say most people who have an old wood stove have them so they don't have to rely on a power company or pellet manufacter for they're heat. At least I do.
We had a Hearthstone woodstove and I loved it's looks and the heat that it made. I just got tired of carting bug filled wood in several times a day and we could never stop the stove from smoking when the wind blew hard. I have several friends that have woodstoves and all of them complain about smoking in high wind. The older I get the less I want to spend large portions of time making firewood. I guess I'm just taking the easy way out. We have a Geothermal heatpump and I wouldn't have to run a stove at all... but we like it.
I'd freeze to death without wood. Even if I lost power my forced air furnace would keep me warm as heat rises as we know. In all the years I've lived here, over 40, never went without power for more than 2 hours. However your BTU per ton of pellets vs split firewood theory doesn't hold up to a candle I'm afraid. Trouble with any pellet stoves I've seen around is they are undersized for the space they are required to heat in many instances.
Quote from: SwampDonkey on February 25, 2010, 04:21:03 pmI'd freeze to death without wood. Even if I lost power my forced air furnace would keep me warm as heat rises as we know. In all the years I've lived here, over 40, never went without power for more than 2 hours. However your BTU per ton of pellets vs split firewood theory doesn't hold up to a candle I'm afraid. Trouble with any pellet stoves I've seen around is they are undersized for the space they are required to heat in many instances. What's the BTU/candle ? You are questioning a sage. BTU to BTU, apples to apples, lb to lb : split logs > any pellets. No theory. Bet your first born.
Well...When I looked at the Forest Products Laboratory ● State & Private Forestry Technology Marketing Unit charts I find that the Net Heating Value of: Pellets =13,600,000 BTU per ton Air Dried Wood = 10,560,000 BTU per tonBut the real bottom line is, to each his own. If you like the wood prep and burning process, then I don't care if you do that and you should not care that obtaining and burning pellets is what I like to do. I grew up in a house where the only source of heat was wood and coal and I have had several periods over the years where we burned wood, including our current house. Since we have changed to pellets, I am very happy with the cost, ambiance and ease of use. I'll burn about 2 tons of pellets this winter at $220 a ton. Not too bad. My Uncles house is about 1500 SqFt and he expects to use 3 tons and his only heats with pellets. My fuel gathering takes the most of one morning and I unload with my TLB forks and the whole 3 tons takes up about 1/3 of 1 bay in my shed. There has never been a pellet shortage in my state. I also consider how mobile I will be in another 10 years and I'm trying configure my lifestyle so that I will be able to deal with that. Enjoy your woodstove...I like them too...at someone else's house.
Remember that the total BTU load for homes in our snowbelt are much higher than in W. VA or Texas ( Texas !). From the limited experience here in northern Maine, pellet stoves have proved by users' experience to be maintenance intensive, medium term unreliable (motors in a dusty environment), and just don't put out enough heat for the money paid. There are not 10 year old pellet burners putting out anywhere here, at least like our wood stoves and furnaces, and boilers.Add to that an uneven supply here of pellets to meet a marketed demand in the few years here that pellet stoves have been marketed and hyped as "clean" and easy and cheap. Can a 75 year old 90 lb lady hump a 40 lb bag of pellets into the hopper BTW: what's a "TLB" fork ? Don't have that .....yet.
TLB = Tractor, Loader, Backhoe. I've handled all of my logs with a loader equipped with forks.
acronyms suck. so sayeth the career military guy...I have made a habit of interrupting every meeting i am forced to go to and making some bureauRat explain his buzzwords and acronyms... tax dollars at work...
Quote from: zopi on March 02, 2010, 08:55:00 pmacronyms suck. so sayeth the career military guy...I have made a habit of interrupting every meeting i am forced to go to and making some bureauRat explain his buzzwords and acronyms... tax dollars at work...Zopi,My old CO would say that POD is DOA Of course that was in the MSO USN... Where the ships were built of wood and the men were made of metal (non-magnetic, of course)...Herb EMC SW USN(Ret)
Like I told ya before, those pellet stoves your comparing are undersized for the space they are heating. Regional btu requirements need to be factored in as you suggest. Heck, if they can make a furnace to burn sawdust on an auger system they will make a more reliable one to burn pellets. Raw sawdust is a lot more dirty than pellets. The neighbors had a sawdust fed furnace for years and burnt green sawdust. Aside for the flu fires they had all the time from burning the green sawdust, it worked well. Never froze to death anyway. When they changed out that furnace for a firewood furnace, they still burned green and still had flu fires. That's proof positive, "in situ", to me that green wood clogs up the flu a lot worse than seasoned. I've lived here over 40 years and never had a flu problem and this house is over 100 years old.
