BID ON A FORUM AUCTION!
DID HE HAVE ANTI-FREEZE IN THE SYSTEM?WE JUST GOT A STOVE BACK THATS 22 YRS OLD AND WANTED A NEW ONE?WE WILL FIX ANY PROBLEMS ALSO IF ANYTHING GOES WRONG
I bought my boiler in 1978, and it was from Babbitt, MN. It is 3/16" steel, and has a 9 gal water jacket. I had to replace the back wall (was 3/16" and went to 1/4") after 10 years, but it has been going strong every winter since it was purchased. Company went out of business, and don't know why. If/when this one gives it up, I will have a new one rolled and welded if I'm still able to cut wood then. (Image hidden from quote, click to view.)
The firebox is horizontal inside the outer water jacket. There is a temp controlled damper below the air-tight feeding door that opens when the water temp in the boiler is below 170 deg F. It closes when above that set point or when the elec. goes off. The house has three zones that are controlled by thermostats and individual water pumps. It is a closed system, so air needs to be bled off whenever the system is opened for any reason. The stainless steel vertical tank behind is a preheat for the domestic hot water heater (gas, and sets behind the wood boiler). The water going into the hot water heater is warmed first by the wood via a copper coil inside the stainless tank. In the summer, the cold water first enters and sets in that 30 gal SS tank and warms up a bit before being pulled into the hot water heater. The backup gas boiler is back in the corner. It is off when the wood fire is going. It is a well-balanced system that has been pretty trouble free for the last 30 some years now. A pic at a different angle showing the pumps. (Image hidden from quote, click to view.)
Over the years, right at 5 cords plus/minus.
