Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: hard starting husky 350  (Read 770 times)
Offline 22chief-1
« on: January 09, 2010, 02:31:11 pm »
any one else have a hard time starting there husky 350 when she is cold, I pull and pull  just isnt any fun.   I will tell you  once she gets going she runs great and starts great when warm but cold she is hard to start. any suggestions
Offline beenthere
  • EIEIO
Re: hard starting husky 350
« Reply #1 on: January 09, 2010, 02:55:39 pm »
Use ethanol-free gas, and keep the saw warm (not being a smart-A.., but don't store it in the cold, and start it often enough to keep it somewhat warm).
Offline Holshot14
« Reply #2 on: January 09, 2010, 03:26:37 pm »
Lol, I just got one off eBay, pulled out of boxed, fueled up (93 with husqvarna xp mix), primed, decomped, and it fired on second pull. That's after it sat in garage all night ( 21 degrees). Check ur fuel and give it a quick overhaul..
Offline chevytaHOE5674
« Reply #3 on: January 09, 2010, 03:29:45 pm »
I have one and it is the most cold blooded saw I have. I set it on the floor of the truck next to the heater, or near the engine of a running piece of equipment to pre-warm it up. That's about the only way it will start in the cold.
Offline Kevin
    • The Milling Masters
« Reply #4 on: January 09, 2010, 03:41:01 pm »
Sounds like a fuel issue.
If you pull it with the choke on the plug should be wet after three or four pulls.
« Reply #5 on: January 09, 2010, 03:58:53 pm »
I've tried everything with mine. Rebuilt the carb, new impluse hose, new fuel hose and filter, checked compression, and checked for vacuum leaks, and it is all within spec. I've just come to the conclusion that it is always going to be a cold blooded saw.
« Reply #6 on: January 09, 2010, 04:36:18 pm »
Push start it.  :D
Offline 22chief-1
« Reply #7 on: January 12, 2010, 10:13:45 am »
 Push starting dont work it is a automatic
Offline ladylake
« Reply #8 on: January 12, 2010, 12:08:34 pm »
 Make sure the choke is closing completly first, if it is try turning the low circut adjuster out 1/4 of a turn or so. That should slow your engine down a little , you might have to turn the idle speed screw in a little to get the RPM's back.  Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Saw Anywhere!
