Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Drying A Big Pine Log  (Read 1470 times)
Offline VT_Forestry
« on: January 06, 2010, 03:27:06 pm »
As the title suggests, I'm looking for advice for drying a large (20" or so) pine log.  I want to make an outside bench so I am going to cut it to a 4ft length and eventually chainsaw it lengthwise so it's essentially in two equal halves, one being the seat and the other being the back.  Normally I would just cut it, slap it together and let the weather have at it but I was hoping to be able to smooth it nicely and put a finish on this so it would hold up for a few more years.  Any advice you guys might have would be greatly appreciated!
Forester - Newport News Waterworks
Offline DanG
Re: Drying A Big Pine Log
« Reply #1 on: January 06, 2010, 04:08:19 pm »
I think it will dry a lot faster if you go ahead and do the splitting.
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #2 on: January 06, 2010, 04:26:52 pm »
First, you wont be able to dry it whole. You will have much better luck with it NOT cracking and checking if you do split it, and when you do, split it at the natural heart check.
« Reply #3 on: January 06, 2010, 05:14:26 pm »
find someone with a bandsaw mill to split it and it will be straight and a lot easier to finish than trying to get rid of chainsaw marks and uneven cutting.
I agree on splitting it now.
Offline red oaks lumber
« Reply #4 on: January 06, 2010, 08:25:47 pm »
diddo to what tom said...
i know nothing related to wood
Offline WDH
  • April 1998 - August 2008
« Reply #5 on: January 06, 2010, 11:13:50 pm »
I suspect that if you put a light coat of anchorseal on the cut/split surface, the log would dry slower and maybe not crack or check as bad if you have the time to let it dry slow.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline boardum
« Reply #6 on: January 07, 2010, 05:28:01 am »
As everyone said, split it first.
Having done alot of this with cedar and fir. stand the two halves on end for a while till they quit wicking water. When the ends do dry up, then anchor seal them. just don't miss the window between when they get dry and start cracking.
Offline VT_Forestry
« Reply #7 on: January 07, 2010, 06:10:07 am »
Looks like splitting first is the way to go, which is what I suspected.  I have a loop of ripping chain that I was going to use since I don't have access to a bandmill, so I guess I'll try that and see what it looks like.  Thanks for all the advice!
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #8 on: January 07, 2010, 06:55:17 am »
Gday
I Agree With Everyone Else  ;)  ;D ;D ;D ;D 8) 8) 8)
With freehand splitting sett you log on a couple of timbers to keep it 6"to12" off the ground then use a level and mark each end with a vertical line then snap a chaulk line along the length take your time ripping and you should be pretty close mate  ;) ;D
with getting a fine finnish just yse a 3or4" planer and the level again and keeping one end fixed and starting from one edge  sweep it across the other edge just repeat this alternating from side to side and end to end and removing alittle at a time and you will get the finnish your looking for
Good luck
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #9 on: January 10, 2010, 11:16:05 am »
I make benches for indoor and outdoor use (up to 16' long).
A 20" dia would make 2 nice center sliced slabs.
Using a band mill will make the work allot easier v.s. chainsaw.
I shed air dry them for a few months at a minimum.  Then plane the top/bottom faces and work the long edges for however the design calls for.  Some are bark on some are bark removed and some have edges very rounded over.
For outdoor benches I use Mckloskies outdoor deck preservative (Wallmart $16.gl).
I turn the legs on the lathe and make a 2"dia. tenon on one end.
I use a drill holding jig with a compound angle shop made jig to drill the holes in the bottom of the bench seat.
White Pine, bookmatched set
Yellow Pine , our "Found in a creek look".
Oak bench set with 2 forked end benches
Ambrosia Maple cut from curved logs
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
« Reply #10 on: January 10, 2010, 03:07:35 pm »
Those are nice.  I love the rustic/cabin furniture.  It's functional as well as One-of-a-kind.  It requires a good eye for design, regardless of how simple it appears, but even the least experienced can get good results.  It's just a matter of looking for materials where no one else looks.  :D
Offline WDH
« Reply #11 on: January 10, 2010, 10:11:58 pm »
That ambrosia maple is beautiful!
Saw Anywhere!
