Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: A little help please  (Read 2039 times)
Offline customsawyer
  • www.thecustomsawyer.com
« on: January 01, 2010, 05:54:52 pm »
On my LT70 remote it has started blowing the fuse on the lubemizer and I think it has a short in it some where but not being used to the remote I didn't know if there was a place that it would most likely happen.  Any advice will be taken but I prefer the right answer. ;D
Re: A little help please
« Reply #1 on: January 01, 2010, 06:12:17 pm »
why, that's easy, Jake.
Unhook the fool thing.
Put a bucket of water up high on the mast and dribble your water through a tube onto the blade.  That'll do it until you run out of gravity.   :D
Offline motohed
« Reply #2 on: January 01, 2010, 06:33:08 pm »
Tom you are going to make him start talking to himself , or worse make him sputter ! LOL  :D
Offline WDH
  • April 1998 - August 2008
« Reply #3 on: January 01, 2010, 06:47:57 pm »
He already talks to himself.  Now I know why.  Its Tom's fault  :)
Jake, I suspect that this is not the kind of help you need since you already know that you talk to yourself and that it is Tom's fault.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline backwoods sawyer
  • LT-70 proto-type, Cooks AC-36 with edger
    • Backwoods Custom Milling Inc.
« Reply #4 on: January 01, 2010, 08:38:09 pm »
I would start by making sure that the power is reaching the pump, if it is then pull the pump apart it may have a bad gear after all the freezing weather.
And Tom.......
100% portable. From our Backwoods to yours....
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #5 on: January 01, 2010, 10:39:54 pm »
WDH did it while you weren't looking... :o  He's trying to side track your thinking about how much QS lumber he got....
Now,  first disconnect the pump, and see if it still blows.  That will separate the pump from the solenoid circuit.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #6 on: January 02, 2010, 12:17:25 am »
What's your weather like down there? Up here, I'd say you had a frozen pump.
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Offline DanG
« Reply #7 on: January 02, 2010, 12:33:57 am »
It ain't likely to be a frozen pump in Central Ga. just yet.  Give it a day or two and it might be, though.  Supposed to be in the teens here in N. Fla starting tomorrow night and lasting for several nights, but we ain't had a freeze yet.  Still got green grass.
Sounds like a bad pump motor to me, or the pump itself is siezed up.  Disconnect the wire to the motor and see if it still blows the fuse.  Is there a way to turn the pump by hand to see if it's siezed?
Offline John_Haylow
  • "If you are going through hell, keep going." W.C.
« Reply #8 on: January 02, 2010, 07:39:48 am »
I had to replace the pump on my mill after the previous owner had it freeze on him.You don't suppose you have a faulty breaker?
John
2004 Wood-Mizer LT40HDG28
« Reply #9 on: January 02, 2010, 07:47:41 am »
I don't think it is a frozen pump but as our coldest so far this winter has been 28 F. When I put in a new fuse and turn on the switch the pump will come on and a bit of water will squirt out for about 4 seconds then the fuse will go.
Offline Magicman
« Reply #10 on: January 02, 2010, 09:15:46 am »
If you determine that the pump is blowing the fuse, then take it apart.  Really, just start taking screws loose.  The pump head should be fastened to the motor with a couple of screws.
Now try the motor with the pump off.  The pump unit is a very simple little rotary pump and a rebuild kit is available for it.
If the fuse still blows, a couple of screws will disassemble the permanent magnet motor.  Oil the sleeve bearings on each end.
The pump on my sprayer has to be taken apart each year.  This type pump is also used in RV water systems.
Offline wwsjr
  • Think Orange
« Reply #11 on: January 02, 2010, 09:41:02 am »
Call Sparks at Indy. I had that trouble last year, but I cannot remember what the problem was. He can probably put you right on the fix.
Willie
Retired US Army, Full Time Sawyer since 2001. 2006 WM LT40HDD51 with Command Control, Accuset, Debarker, and Lubemizer. ED26 WM Edger, Ford 3930 w/FEL, Ford F350 Dually, Prentice Log Loader. Stihl Saws & Logrite Canthooks
« Reply #12 on: January 02, 2010, 11:00:19 pm »
I had the same problem when I got my mill. I took the pump apart out in the field and found one of the three plastic gears was damaged and not meshing with the other two. I just took the gear out of the pump and put it back together and it is still pumping today. Like magic posted, just take it apart and see what is going on in there they are as simple as a water meter to work on.
« Reply #13 on: January 03, 2010, 06:34:55 pm »
Thanks for all the help folks.
« Reply #14 on: January 04, 2010, 12:27:26 am »
Well what did you find?
Offline slider
« Reply #15 on: January 04, 2010, 02:46:27 pm »
probably not your problem but ice did pop the fuse on mine last winter jake     al
al glenn
« Reply #16 on: January 05, 2010, 04:22:20 am »
I haven't had a chance to hunt for it to much yet as I have been down at the other sawmill cutting a order of 12X12X36' that has to go out on the truck on the 6th of Jan. I am hoping to finish that today and get back to this mill in the afternoon.
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
« Reply #17 on: January 05, 2010, 01:19:58 pm »
Unplug the pump motor and see if the green light now comes on. If it does you have a shorted diode that is built into the motor. Replace the pump motor.  If the fuse blows with the motor unhooked check the diode wire that is connected to the red and black wires that come from the control. It is located about 6 to 8 inches away from the terminals. Disconnect it and try again. If the fuse holds replace the diode wire. If it still blows then we have a issue on the wires.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
« Reply #18 on: January 05, 2010, 06:51:06 pm »
Sparks are you giving this advice on here because you don't want to have to talk to me? ;D
Not that I blame you as I can be a pain.
Offline sparks
  • Sponsor
« Reply #19 on: January 06, 2010, 08:54:59 am »
Always a pleasure to talk to you. You know how to reach me if you need more help.   Thanks   :)
Saw Anywhere!
