Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Comparing heating sources  (Read 2605 times)
Offline Qweaver
  • The cabin is done and we love it
« on: December 23, 2009, 08:52:02 pm »
I've spent a lot of time trying to come up with good info on comparing efficiency for heating systems.  I ended up with a pellet stove and a geothermal heatpump.  But the more that I look,  the more confused I become.  The Jan/Feb Grit has a pretty good article comparing all types of heating systems except Geo and some of the conclusions surprised me.  The cheapest fuel in cost per million BTU was coal. ($4.01) Then wood ($9.09), Pellets ($12.12), Gas ($13.80), Fuel oil ($16.94)  then everything else over $25.
I find it hard to believe that wood is cheaper than pellets and that gas is not much more than pellets.
I use one bag of pellets a day on average. I paid $4.40 per bag this year so that's about $132 per month plus the electricty to run the blowers.  Not real cheap.  I should really shut down the pellet stove and just run the Geo.
I just wonder how good the published figures actually are.  But for me the bottom line is that I like how the pellet stove and the heat pump work together to make a really cozy house with little effort on my part.  We'll see how the electric bill is and that will tell me more.
So Many Toys...So Little Time  WM LT28 , 15 trailers, Case 450 Dozer, John Deere 110 TLB, Peterson WPF 10" :D
Offline splitter
Re: Comparing heating sources
« Reply #1 on: December 23, 2009, 09:31:20 pm »
I think alot depends on where you live and what you have access to. Coal burns very hot but you can't get it in my area. I have plenty of wood so I have a outside wood furnace that heats my house and provides hot water. It also depends on how much time you can put toward getting your fuel, your age may also be a factor. Nothing is cheap, but hydro may be the cheapest if you live in a area where you could put in a system. I visited a person who had a hydro system and he produced enough electricty for about three homes. His meter ran backwards and he has never caught up, maintenance was minimum. Splitter
Offline genesis5521
« Reply #2 on: December 23, 2009, 09:31:43 pm »
I'm assuming your bags weigh 40 pounds, so 50 bags would make a ton. Your cost of $4.40 per bag is right in line with $220.00 a ton for pellets in my area, and so is your usage.  Before I put a Napoleon high efficiency wood burner in my living room, I checked out wood stoves and pellet stoves. I forget where I read it, but I found an article which recommended wood over pellets, as the cost of pellets could rise and fall with the price of other utilities. The same could be said if you buy firewood. But I make my own firewood, so my cost is very low. But the effort required to make it is very high. I know a few older folks who replaced their wood stoves with pellet stoves cause they were getting up in age, and just couldn't make their own firewood anymore, and didn't wanna mess with firewood anymore. Pellets are clean and easy to handle. I'm 64. At some point I may switch to a pellet stove. I wanted a blower on my stove, but the installers said that because of the layout of my house, I really didn't need one. Now I like it when a company tells me the truth, rather than making a few more bucks off me. You got what you got and you'll make the best of it. I don't think you made a bad choice.
Offline Brucer
  • The Kootenay Sawyer
« Reply #3 on: December 24, 2009, 01:05:14 am »
Usually when they come up with these numbers, they assume that the wood stove is burning well-seasoned wood and is operating at optimum efficiency. Well-seasoned wood is nice, but not everyone can supply/produce it all the time. "Optimum efficiency" may put out too much heat or not enough, so you might have to run a wood stove at well below optimum.
With a pellet stove you get a wide range of outputs at optimum efficiency and you don't have to worry about seasoning your fuel ;D.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline moonhill
« Reply #4 on: December 24, 2009, 08:07:08 am »
As comparison I try to think if every thing shut down what would be the source of energy/heat?  The simpler the product the more efficient.  Wood from the back forty is the solution I come up with.
In addition I see most houses as being too big and inefficient.  They should be kept to a minimum and well insulated.  There are many other factor as well which could and should be looked at.  The position of the dwelling as an example.  How about where it is located in relation to the other needs one may require, trips to town for an example, all part of efficiency.   We have to take in the whole picture.
Tim
Offline moonhill
« Reply #5 on: December 24, 2009, 09:42:52 pm »
Maybe something like this:
We have to keep that global warming in mind ::) You could do it for other reasons as well.
Tim
Offline woodmills1
  • the truth shall set you free
« Reply #6 on: December 24, 2009, 10:06:28 pm »
the cheap secret
have lotsa free wood
go outside many times and put it ina stove
save so much oil and gas money
pay for outdoor appliance in 2 years
did I say lotsa wood, go outside often?
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline tughill
« Reply #7 on: December 25, 2009, 05:00:07 pm »
To accurately compare heating costs, you must use a chart that shows the BTU (amount of energy) of a given amount of fuel, (tons of pellets, gallons of fuel oil, etc) and come up with  a cost per BTU of energy, based on local cost of each type of fuel.
http://www.readingstove.com/support_chart.html
This page shows just such a chart.  Also keep in mind that burning wood is probably less than 70% efficient meaning that 30%  of the heat goes up the chimney, or is needed to dry the wood in the stove before it will actually combust.
Electric heat is nearly 100% efficient, because it requires no chimney, all heat produced heats the house.
Oil and gas, depend on the boiler, furnace type, but are probably above 95%, definitely above 90%.
Pellet heat is also quite efficent, so that needs to be considered.
I burn wood, with electric heat as a supplement, or is used when I'm away, but I have municipal electric that is quite cheap.
I like wood pellets and I'm considering putting in a pellet boiler when I build my new workshop.  The other advantages I see with pellets are that they are locally american made, shouldn't have big future price swings like fossil fuel, clean and with a large hopper and automated feeder, they are very little work to keep the heat going.
"Those who hammer their guns into plows, will plow for those who do not."- Thomas Jefferson
Local Farmer here won 10$ million in the lottery, when asked what he was going to do with his winnings, responded, "Keep on farming until that's all gone too."
Offline tughill
« Reply #8 on: December 25, 2009, 05:04:59 pm »
And personally, I think burning all that 'free' wood comes at a pretty high cost.  I have several thousand $$ invested in chainsaws, woodsplitter, tractors dozers, fuel, etc to cut split and burn all the 'free' wood...not to mention labor, dirt in the cellar from wood, space that wood takes up in the cellar to get it really dry....
I mostly burn wood to get rid of it...I am cutting to improve my farm, and woodlot.  Perhaps I should sell the wood and buy pellets?  I'd probably be $$ ahead.
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #9 on: December 25, 2009, 05:36:50 pm »
You might like to download my BTU comparison Excel spreadsheet, where you can insert your actual costs, from:
http://www.forestryforum.com/board/index.php/topic,39977.msg576183.html#msg576183
Someday when I have a lucid moment I might add a column "Cost/MMBTUs". Too many cobwebs to do it today.  ;D
(I'd sure like to buy a gallon of electricity in Tughill's link. "Fuel Unit Cost $/Gal."  :D  :D  :D )
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
http://www.xmission.com/~sherwin/sawyer1.
Online beenthere
  • EIEIO
« Reply #10 on: December 25, 2009, 06:04:43 pm »
I expect pellets as fuel to fluctuate very close to the oil and gas prices.
Just can't imagine a pellet supplier not setting prices relative to the other available fuels, and less on how cheap or efficient it is to produce the pellets. Competition may enter in here, but not until there are plenty of suppliers out there to choose from.  ::)
Just my WAG
Burning wood pellets takes me back to the 50's when folks would get coal delivered by the ton, and dumped into a coal bin under the porch. Then my job was to shovel it and put it in a stoker (bin with auger) that would auger the coal into the furnace on demand. Had to remove the clinkers, shake the ashes, and carry out them out in metal bushel baskets. I'm betting the BTU's per volume of delivered fuel were much higher for the coal than for pellets. And other than that, pretty much the same.
Offline woodmills1
« Reply #11 on: December 25, 2009, 08:20:29 pm »
my free wood is all residual to my business, stuff I cannot sell or cut on the sawmill.  All of my equipment is supported by the business and I would gladly spend the labor time to save the $4500 or so a year I would be spending on oil and propane.
Offline Jasperfield
« Reply #12 on: December 25, 2009, 08:34:42 pm »
I have a new pellet stove that I bought from a dealer. It was his display demo unit. I've never used it and should probably sell it.
Pellet stove operating cost should also include electricity. Albeit a small amount.
And when the power is off, the stove is not far behind it.
However, the idea of clean, pelletized & bagged, readily available, and easily stored fuel is certainly attractive especially when combined with thermostatically controlled heat.
I, too, agree that we will see all heat sources priced equivalently on a BTU basis; And will see all energy priced equivalently on a kw (or similar) basis. It's coming.
Offline moonhill
« Reply #13 on: December 26, 2009, 07:46:46 am »
One can look at all the charts they want, then select the most efficient unit and install it in a hot house with two layers of plastic and it still won't be efficient.  A large part which needs to be assessed if the structure itself.  Everyones abilities, needs and wants are different.   You can not say one is worse due to the dirty, labor intensive "free wood" aspect that is pure perspective.  As pointed out when the power goes out, for any numerous reasons, most systems fail, with one exception.  Sure, look at the charts but don't stop there.
We have become addicted to an easy life style and it comes with a cost.  If things should fall apart, for any numerous reasons, we will be in deep doo doo.   I think it boils down to how prepared you are to pay the cost.  Take for example hurricane Katrina, things went bad in a matter of days.
I like how Qweaver says "with little effort on my part", that explains people.
Tim
Offline Jasperfield
« Reply #14 on: December 26, 2009, 08:27:32 pm »
At some of the quick-lube oil change businesses I've seen different types of (commercially produced) oil burning heaters that are fueled with old motor oil they've drained during the course of business.
They are fan forced and electrically fired.
I think those are the neatest things even if they use electricity.
Offline red oaks lumber
« Reply #15 on: December 27, 2009, 11:48:05 am »
the only fuel i see that won't go up in price like all other fuels is, the firewood you cut yourself. a person will never be able to heat your home in the winter for "free".just how much are we willing to spend to keep warm?. that answer will be different for all of us.
 for me not being dependant on marketable fuels. gas, elec, pellets. my heating costs should remain close to the same every year.
i know nothing related to wood
Offline tughill
« Reply #16 on: December 27, 2009, 03:51:12 pm »
Well,  like I said I burn wood, lots of it, but I just think it's not accurate to say that it's free.  And I do have a backup system in place, so If I go away for a few days my pipes won't freeze.
Ultimately the cost of firewood has gone up as other fuel sources have gone up, just because price is sometimes determined as 'whatever the market will bear', and "cheap' is just relative to the alternatives.
Even if you burn wood that you have available for 'free' that wood has a sort of 'opportunity cost'.  Meaning that, potentially you could sell that wood at a market price and use the $$ for some other purpose.  So even if the wood is free, it has value, and you can't ignore that value.
If in your woodlot you could dig 6 inches in the ground and turn up gold bars for 'free' would you stack them up to make a chimney for your house?  No, you would sell them for a lot of $$, and move somewhere warm where you didn't need any heat, like your own private island in the tropics.
Offline stonebroke
« Reply #17 on: December 27, 2009, 04:00:01 pm »
That is how I think of my trees ,just gold on the stump waiting to be harvested.
Stonebroke
Offline Paul_H
« Reply #18 on: December 27, 2009, 04:19:09 pm »
Quote
We raised our house and built a floor under it 9 years ago and doubled the size.Before we had done that,our annual heating bill(1996-97) on propane was $1800,and the following year was just over $2400.We bought a little woodstove and set it where the propane furnace had stood and burned about 5 cords per year(valued then at $150 per cord)
When we raised the house and added better windows,doors and insulation our consumption rose to 7-8 cords per year.
If I would have bought the wood in 96 and 97 it would have cost $750 at market price with a savings of at least $1000.As it was,I was cutting the wood at work when possible and bringing it home so the savings were greater.
If I had taken that same cordwood and sold it to buy another fuel source,it would have made for a long cold winter.
and we shiver when the cold wind blows
Offline woodmills1
« Reply #19 on: December 27, 2009, 05:07:17 pm »
The real difference buring my free wood in my outdoor furnace is that we are warm, spending fuel money we used to be chilly
Saw Anywhere!
