Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Frozen wood  (Read 2177 times)
Offline PlicketyCat
  • Gender: Female
  • Enjoying Life's little surprises!
    • Off-Grid in Alaska
Frozen wood
« on: December 17, 2009, 10:29:10 pm »
On another recent thead, I was talking about bucking and splitting frozen logs for firewood. Most of the logs are spruce, so normally fairly soft and easily cut, split, or worked. But someone asked me if they would approach "hardwood" hardness when they're frozen solid (yes, sub zero temps for a month or two will freeze even a 24" d log solid). Well, I don't have the answer, so I was wondering if anyone else did?
I know that my poor Husky doesn't chew through the frozen stuff in the winter with the gusto it does during the summer, but I don't know if that's due to the wood being harder or just because the chain is freezing up (literally freezing the chain & oil on the bar - we use 5w motor oil since regular chain oil is useless for us in the winter).
What do ya'll think?
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. --- Oscar Wilde
Follow our adventures at Off-Grid in Alaska blog.
Offline Gary_C
  • Sunrise on the Prairie
Re: Frozen wood
« Reply #1 on: December 17, 2009, 11:59:58 pm »
I believe the problem with frozen wood is due to the difficulty in clearing chips due to refreezing rather than hardness. I cut with a harvester a lot in the winter and with a .404 chain pitch, it seems to cut the same in frozen wood as any other time. But that is with a lot of chip clearing space and high chain speeds.
I also can say that chain lubrication is not very effective in very cold weather and snow. I have seen that in corn heads that have to run in the snow where the grease is washed out of all spaces because of the abrasiveness of the snow. Same thing is true for loader pins when working in snow. It is hard to grease things in the cold and the snow will wash all the grease right out.
Offline zopi
Re: Frozen wood
« Reply #2 on: December 18, 2009, 12:42:35 am »
Will Vegetable oil freeze in that cold? I use it for bar and chain lube in my saws..and no i don't want to debate which is better..and no amsoil doen't make veggie oil. :D
you could maybe thin that 5w with say a tenth part kerosene and wake it up some..
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline tughill
Re: Frozen wood
« Reply #3 on: December 18, 2009, 08:52:12 am »
Frozen wood regardless of species can be *very*hard.  Kinda depends on moisture %, but I've cut a lot of frozen logs in the sawmill over the years, and can definitely say it gets hard as a rock.  It should still cut fine with a chainsaw though, softwood will cut way slower, as you have seen.  For frozen cutting, you want full chisel chain, and want to keep it very sharp.  There is winter weight bar oil available, I personally think motor oil is not really what you want.
"Those who hammer their guns into plows, will plow for those who do not."- Thomas Jefferson
Local Farmer here won 10$ million in the lottery, when asked what he was going to do with his winnings, responded, "Keep on farming until that's all gone too."
Offline stonebroke
Re: Frozen wood
« Reply #4 on: December 18, 2009, 08:59:03 am »
Would a skip chain help with chip clearance?
Stonebroke
Offline Sprucegum
Re: Frozen wood
« Reply #5 on: December 18, 2009, 09:38:04 am »
Your motor oil is probably slowing you down more than its helping. If you can't get winter chain oil try using ATF(automatic transmission fluid). You can mix the ATF with your motor oil to get the viscosity you want.
Keep sharp and keep your rpms up - all season advice  ::)
Offline fuzzybear
Re: Frozen wood
« Reply #6 on: December 18, 2009, 02:08:46 pm »
   Up north the trees grow WAYYYY slow. The growing season is much shorter. The density of the wood is greater than the same species growing in the south. In the winter spruce that is frozen is as hard as a rock.  Think about putting a cup of tree sap in your deep freeze. We have temps lower than that.
   A month of -40 to -50 will freeze even the softest of wood hard as granite.
   I use canola oil all year round. I use it down to -30. After that I sit in the cabin by the stove.
I've used a lot of oils over the years.  Even 5w oil thickens up to sludge at -10.
I used to keep a small fire going while cutting. I would keep the jug beside the fire to help keep it thinned.
   A skip chain definatly works better on frozen wood. Sharpen often and it should work fine.
I never met a tree I didn't like!!
Offline golden foot
Re: Frozen wood
« Reply #7 on: December 18, 2009, 02:40:23 pm »
okay, chisel ground, skip tooth chain. The trick is to file it more straight across than at an angle. Use a flat file so that you have a square corner. Bailey's sells them. A lot of saw shops don't even know what they are. As far as oil goes we had good luck using oil that was drained out of diesel engines. The reason is that it was thinner and the diesel helped cut the pitch in the wood. If the oil is still too thick add a little more diesel, not gas as it is explosive. Another thing you can do is use a worn out bar that has loose grooves. When we were running 6' bars we used to buy .063 gauge bars and run like .053 chain.
SOLO 103CC SAW PRENTICE 410 LOADER CHRISTY YARDER,EAGLET Motorized CARRIAGE TIMBERJACK AND NEW HOLLAND SKIDDERS JOHN DEERE 550 DOZER LUCAS 830 MILL BIGGEST TREE FELL: 80,000 BOARD FEET WM LT40 Manual
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #8 on: December 18, 2009, 05:15:45 pm »
Looks like we're going to have to change chains in the winter then!  And one of the locals told us to use 5w... geez, he must've been teasing the newbies  ;D  I'll have to check at Rod's Saw Shop for the winter weight chain oil, or use veggie or ATF.  Using Canola might work, I think I have one of those monster 5 gal cans they sell at Costco out in the shed... if it isn't frozen by now, it's probably our best option.
Now all we have to do is figure out an easier way to split those big rounds. The smaller stuff splits easy, even/especially when frozen; but the first split on those big-uns' is murder... we tried a star-wedge and an 8-lb maul, a 12 lb splitting maul with a straight edge and wide body, and the axe. Poor log was beat to heck before it finally split... after 10 minutes playing whack-a-mole with it. Man, we so need a log-splitter LOL
Re: Frozen wood
« Reply #9 on: December 18, 2009, 05:32:29 pm »
plickety cat,
Those big "rounds" will come apart easier if you start at the edge and split off pieces parallel to the bark until you can manage splitting the entire thing.  You break off a piece to open up the log and then work around it, making the round smaller as you go.
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #10 on: December 18, 2009, 05:44:52 pm »
Which reminds me... I've been using the standard Spruce-Pine-Fir tables for span and load calcs, but our local forester at the co-op extension said that our trees (up north) were much harder and you could build with a lot less dimension than those tables call for (even with our snow loads).  Have you found that to be the case? If we can use smaller timbers, then the house would weigh less and therefore would need to support less weight (funny how that works - law of diminishing returns I guess).  Do you know which tables I should/could be using instead? It's hard to find anything that addresses all the differences found above 55° North!
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #11 on: December 18, 2009, 05:49:49 pm »
plickety cat,
<<smacking forehead>> Doh - that was so obvious, I missed it - I am such an idiot  ;D
Re: Frozen wood
« Reply #12 on: December 18, 2009, 05:57:42 pm »
Nah! you're no idiot.  It just looks easier from down here.  :D
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #13 on: December 18, 2009, 06:00:52 pm »
I must have been suffering from the "confusion and lack of concentration" that happens with hypothermia. That's my story and I'm sticking to it :D
Offline arojay
Re: Frozen wood
« Reply #14 on: December 18, 2009, 06:30:44 pm »
I use TDH fluid that I drained out of the skidder, mixed with a little bar oil for tack.  If you don't have a skidder this could be a problem.  I used to use regular winter bar oil and cut it with kerosene to get to a flowing consistency.  I don't run the skidder if it is below -35 but I will cut firewood in any temperature.  Dry spruce isn't too much different when frozen but green is really hard.  I use full chisel all of the time.  It will dull faster than semi-chisel in green wood but not much different with dry.  I have tried skip in winter but I didn't find a great deal of difference.  Splitters are great if it's not too cold.  Mine doesn't work so well at -30 or 35.  I like to save the biggest rounds of dry spruce to split with the maul and sledge when it is around 40 below, they just pop apart at that temperature.  Are you between Glennallen and Palmer?
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #15 on: December 18, 2009, 06:56:26 pm »
Maybe we just didn't wait until it was cold enough then -- it was only 23 below yesterday LOL
We're between Fairbanks and the Tanana River, on the Elliott Hwy, in . Or, as one person put it, about 4 feet from the middle of nowhere ;)
Offline Mooseherder
Re: Frozen wood
« Reply #16 on: December 18, 2009, 07:11:50 pm »
At least your not far from the Airport. ;D
Lane Circle Mill Project
Offline PlicketyCat
  • Gender: Female
Re: Frozen wood
« Reply #17 on: December 18, 2009, 07:44:09 pm »
Yes, the airport makes Manley almost a bustling metropolis... NOT!!
But at least we get mail fairly regularly, can fly into F'banks on the mail plane, can charter an air service and can get air freight (if it's small enough). Of course, the biggest thing is that MedEvac can land there, but where we're at, it's easier for those guys to pick us up at our neighbor's private strip ;)
Offline zopi
Re: Frozen wood
« Reply #18 on: December 18, 2009, 07:56:22 pm »
We're between Fairbanks and the Tanana River, on the Elliott Hwy, in  Or, as one person put it, about 4 feet from the middle of nowhere ;)
I used to live just the other side of knowwhere...
Got Wood?
And lots of junk.
Offline fuzzybear
Re: Frozen wood
« Reply #19 on: December 18, 2009, 08:34:00 pm »
   Just wait till -40 then them big rounds split like an apple.
   As far as using the logs for building, I build wall tent frames out of small trees.  Of course a 4" diameter tree 12' tall is 125 years old.   I build a timber frame type of frame. Biggest one I built was 16x24.  The tarps will rot off of it before the frame will break.
   The first one I built was 5 years ago it is still standing. The roof joists are 3" poles spaced 3' on center with a 4" ridge pole. I have had 4' of snow on the roof and it never budged.
   If you want building logs I would stay away from "river" groves and look in the valleys and crevices for them. The reason being is those trees have extremley short growing season. Some of them you have to use a pin and magnifying glass to count the rings, they are that tight.
   Also I would look into any burn fields around your area.  The intensity of fires more or less "kiln dries" the trees. After 2 years you have trees that the bark is falling off and they are not going to twist or shrink any more than they are.
   I always enjoy going "tree hunting".   We have so many options here in the north.  As long as it's spruce, poplar, or birch. ;D :D
Saw Anywhere!
