Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: how many sections of chimney  (Read 802 times)
Offline firefreak47
« on: December 15, 2009, 02:45:21 pm »
hi all i have cb 5036 second season now and was thinking about adding couple more sections to the chimney it does not smoke anymore than any of the wood stoves around here except a little when i first load it so was wondering how many sections others are using and how often do you have to clean the chimney and how do you do it with more sections added on thanks
Offline wi woodcutter
  • United we bargain. Divided we beg!
Re: how many sections of chimney
« Reply #1 on: December 15, 2009, 03:10:39 pm »
I have a CB5036 and I have two sections of chimney on it.
I was thinking of putting another section on it, but it does not seem to smoke as bad as I thought it would.
2-066's ms660 034av 076av huskee 27ton splitter CB5036
A guard dog needs food, water, shelter, walking and training.
My Smith & Wesson only needs a little oil!
Offline woodmills1
  • the truth shall set you free
« Reply #2 on: December 15, 2009, 04:18:41 pm »
my free heat machine has a one foot chimney
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline terra8186
« Reply #3 on: December 16, 2009, 08:22:06 am »
I run two sections.  I am in an open area and it doesn't bother anyone.  I have run my CB6048 for 4 years.  I have never cleaned my chimney with a brush or even looked down it.  Occassionally I leave the door open for a couple of minutes and push the wood to the back and try to burn it out.
I paid the stove off last year.  Cost of stove = 3 years of propane.
Offline firefreak47
« Reply #4 on: December 16, 2009, 06:33:21 pm »
 i have 2 sections right now and wasnt worried about cleaning those because i think its hot enough that there wouldnt be a build up but if people have added more sections thought it would start cooling off near the top and then may have to be cleaned at some point
Offline PlicketyCat
  • Gender: Female
  • Enjoying Life's little surprises!
    • Off-Grid in Alaska
« Reply #5 on: December 19, 2009, 02:07:11 am »
Standard chimney guidelines say you should have the chimney at least 1' above the roof and 2' higher than any vertical obstruction within 10' (including the peak of the roof) to maintain good draft and a cleaner burn. Also reducing any bends in the pipe and insulating the pipe can also help. Make sure the draft intake and damper unit are working properly since an oxygen-starved fire just smoulders and smokes.
I don't have the CB, but have a fair bit of experience with indoor stoves. During heating season, if you're burning full-time, or a lot of softwood, or a lot of green wood you should probably sweep your chimney every couple of months (or at least inspect it). Lots of places sell the extension poles & brushes, and it's just a matter of getting on the roof or a good ladder, removing the weather cap/spark arrester and then feeding the brush and flexi-poles into the flue (with the damper open). Usually 3 or 4 good passes is enough to clear any creosote.  Burning her hot and wide open first thing in the morning will also help reduce the build-up and improve performance.
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. --- Oscar Wilde
Follow our adventures at Off-Grid in Alaska blog.
Offline Holmes
  • 1840 house
« Reply #6 on: December 21, 2009, 07:54:35 pm »
Hi all. The taller you make the chimney the colder your smoke gets. Cold smoke makes lots of creosote. Outdoor boilers tend to run with low smoke [ stack ] temperatures. Best to keep chimneys short unless you want to run a hotter fire in the boiler and that uses more wood.
Think like a farmer.
Saw Anywhere!
