Get your Forestry Forum Hats while they last!
I am having trouble drying black walnut from South America. North American is as easy as rolling off a log. At any rate, a guy tells me the other day that they soak their walnut in ponds before they dry it. Must be something to it.I have dried some very hardwood from Australia called jarrah. I read that it is so hard that it was used for pavers only. It said that jarrah pavers still lay under some streets in Europe.And those are the odd facts for the day.
Are the Pavers all End Grain? Are they always end Grain?Thanks for the PhotosBoardum
Ole,I'd try a couple of things. As you described boiling the cuts may work great. Also keep in mind that this was old world tech so it may be as simple as cutting everything green and using them before they dry out. In which case cutting green and dipping both ends in wax to keep them till they get to the ground may also do the trick.I have several friends who travel and buy wood in Europe, I'll ask around for insight. Best of luck.
