Get your Forestry Forum Hats while they last!
ShannonThat was an interesting read, and makes me want to scratch an itch when reminded of the 70's and being involved in the new digital (and analog) control design and build (then testing to locate the problems in the design layout or the failure of a chip to do its job). Then out with the solder wick and put in a new chip, etc., etc. Things were big those days compared to the mini-chips now.
HEY SHAWORTH WOULD YOU BE INTERESTED IN BUILDING ANOTHER ONE ? IF SO HOW MUCH?
60 amp at 12V sounds correct.There are also table saw digital gages that can measure position up to multiple feet. The gage is mounted on a aluminum bar and the detector can slide up and down the bar.They use a positional coded tape so the reader know distant and position. There is a problem with vibration that makes reading position difficult.
Shannon,On my previous post I mentioned about the chain on the head. What I found was that if the chain is not tension properly the setworks would not be as repeatable. This was based on observing the pointer each time I stopped in increments of say 1 inch. Even thought it was not a lot it the accumulated effect could be a issue. The chain may be a problem.Ron
Does your set up have a linear positioner so the head knows where it's at at any time or do you just use as a setworks using preset heights
Sounds interesting my mill is homebuilt has .2 pitch leadscrews to move up and down instead of a chain do you think this would be a problem? let me know when you get a price ironed out and i think i can help you with alum. wheels
I like these guys, on this page there are multiple encoder options:http://www.sparkfun.com/commerce/advanced_search_result.php?keywords=encoder&x=0&y=0&search_section=products
However you do it, remember sawdust. It can/will get into any open space and has a way of covering everything. Be sure that a layer of sawdust will not affect any measuring device.
BTW Shannon a belated big welcome to the forestry forum. I completely agree with your take on the advantages of using a dedicated micro processor instead of adapting a laptop. You see, I have this old lunchbucket that has a monochrome plasma display, and my mill already has all the relays and drivers in the form of the remote control. A hall effect pickup on the head drive pulley to trigger the data in pin on the serial port..Now lets see, 8 output pins on the parallel port, 1 for head up, and another for head down. Two more for head forward and backward, another to activate the clutch to start the band moving......Might be simpler to program it in machine code, but I've done bit of that. You can probably see where all this is headed, and NAW I'll probably never do it. Seriously, thanks for posting the links, I already checked them out. It's been decades since I did any of this sort of tinkering and I'm impressed. I think I may be purchasing a butterfly....
