Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Homegrown Setworks  (Read 9035 times)
Offline shaworth
    • VH Timberworks
Re: Homegrown Setworks
« Reply #100 on: January 15, 2011, 01:57:48 pm »
Everyone,
It has been over six months since my last post.  I owe the many of you who have been following this project an update.  Plus, I have encouraging developments to report.
Life has a way of interfering with these hobby projects.  I'll start with a brief run-down of "real life".
First, early last summer I moved the family from Lincoln NE, to Richmond VA.  At the same time I went from being a contractor for my primary client, to a full time employee.  Anyone who has made the sift from contractor to employee knows that employees have a lot less flexibility.  The move and everything that went with it pretty much consumed the entire summer, and most of the fall.
The other challenge I faced was I had no workshop in VA.  Since I rent here in VA, I couldn't put up a small building.  So with the wife's blessing (she is a saint most days) I purchased a 23' travel trailer which I converted into a sweet little workshop in short order.
Now, back to the project.  When you work on something for over a year, the warts start to really bother you.  Some of these warts start to look like cancerous tumors.  And cancer must be removed.  So, what I'm trying to say is that I redesigned most of the system.  Again.
I'm calling this the second generation solution, although it is really the forth combination of hardware.  I had two goals this time around.  First, eliminate the custom electronics and only use off-the-shelf parts.  I had bit off more than I could chew.  Second, I needed a more reliable way to connect everything together.
The previous architecture is essentially a control board, a sensor board and a relay board.  There is actually a forth component, and I wish I had recognized this earlier.  The interconnects between the components.  In the first versions these were all wired together, using shielded communications wire.  The method I used to interconnect them wasn't reliable.  One of the decisions I made this summer was to replace my previous interconnects with a regular old Ethernet network.  Ethernet is very good at moving data long distances, reliably.  So the new architecture uses Ethernet as a data bus.
The relay board is another thing that I was building by hand before.  I found a nice, affordable, Ethernet controlled relay board.  It just plugs into the network and has screw terminals for attaching equipment.  Easy as pie.
The control board (main CPU really) was already an industrial embedded computer running Android.   It was already network equipped, so it too just plugged in.  Also most of the software "just worked".
Anyone who has followed this project knows that the sensor has been a challenge.  The holy grail is an affordable, off the shelf sensor.  My brother and I have found two very promising sensors.  One is a string-pot, the other is a linear sensor that operates a lot like a mouse.  Neither of these has an Ethernet interface.  However I have located an embedded micro-controller (http://www.sparkfun.com/products/9474 - the nerds out there will appreciate this link) that will mostly replace my home-built circuits and provide the Ethernet connectivity.
Several of you have contacted me directly.  I really appreciate the feedback and encouragement.  I had promised myself that I wouldn't post anything until I had a working system to demonstrate.  But, the interest in this project remains high and those who have been following this for over a year deserve an update.
To recap, the second generation architecture is moving right along.  And I am very happy with the hardware design, this time around it feels completely "right".  It eliminates nearly all custom electronics from the picture.  Is very affordable, and is proving to be very easy to program the software for.  One of the nice "fringe benefits" of this approach is that the the connection between the control board and the rest of the system can be wireless.  No additional work necessary, just attach a wireless access point and away you go.  From an engineering standpoint, remote set-works is a gimme.
Again, thanks for the continued interest in this project.  I'll let everyone know when I have something working.  It has been over a year, and if I've learned one thing it is not to guess how much longer a project will take.  All of the off-the-shelf technology has really reduced the complexity of the build.  I'm optimistic that I can get this knocked out before the coming of the zombie apocalypse.  Please keep the encouragement and suggestions coming.
Shannon
Dremel tool, X-Acto knife, Sherline 5400 CNC mill
Offline sdunston
  • New York (the great tax state)
« Reply #101 on: January 15, 2011, 06:51:15 pm »
Keep working on it I am certin that there is a lot of interest in a good affordable,self installed setworks.
Thanks for the update,
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Offline Woodwalker
  • Old, ugly, rude, cude and sociability un-acceptable.
« Reply #102 on: January 15, 2011, 07:36:58 pm »
I wondered where you got off to.
I seen houses with wheels, but your shop, you gonna call it a mobile shop or a trailer shop ???
Just cause your head's pointed, don't mean you are sharp.
Offline shaworth
    • VH Timberworks
« Reply #103 on: January 16, 2011, 09:53:40 pm »
I call it an eyesore (it was made in '76) in the back yard :)  I tell my 4yo son it is my workshop.  But, I can't complain too much.  At least I have a place to work / escape.
Several of my friends where all psyched about the thing - I think they had visions of hanging out and shooting the bull out of earshot of the women folk.  One look at the CNC machine, scopes, chemicals, electronics, manuals, glassware and other nerdy bits crushed their dreams of mini-fridges, recliners and wide-screen TVs.  The thing is packed to the gills.
Next summer I'll tear out the bathroom, that should free up a lot of space.  But only after I finish the darn project.
Shannon
Offline shaworth
    • VH Timberworks
« Reply #104 on: January 08, 2012, 05:25:10 pm »
Time for my annual update.  Believe it or not this project isn't dead.  During the past three months a lot of progress has been made.
Over the holidays I was able to visit my brother, and his mill, for the first time in two years.  While I was there we tried out the electronics and I did a ton of work on the software.  I was able to verify that the sensors and electronics worked perfectly.
The software has some rough edges, but is headed in the right direction.  All of the critical bits are working perfectly.  I expect to release something this spring.  :)
Shannon
Offline eastberkshirecustoms
« Reply #105 on: January 08, 2012, 05:33:57 pm »
Good to have you back with an update. I, for one, am waiting in anticipation.
Offline shaworth
    • VH Timberworks
« Reply #106 on: January 08, 2012, 05:43:49 pm »
In related news, is there a brave soul in the Richmond VA area who has a woodmizer and would like to try this when it is ready?
Thanks,
Shannon
Offline Woodwalker
« Reply #107 on: January 08, 2012, 06:11:50 pm »
Send one down to Texas and I'll start the Southern testing and proving grounds for you  move_it
Glad your still around, keep at it.
Offline shenandoahsawmill
« Reply #108 on: January 13, 2012, 12:22:10 pm »
Shannon; I live near Winchester Va. and have an older LT-40 and a Povlsen double cut bandmill. I need a setworks for both saws. It would be fantastic to adapt something that you have worked so hard to develop. Thanks Gary Smith 540-955-3956
Saw Anywhere!
