Get your Forestry Forum Hats while they last!
I am not going to argue with any of you because I feel the same way about girdled trees making for an unsafe woods.
the way i look at it is id like to play ring around w the idoit that marks hundreds of those on timber harvest sites. the guy sprayin the paint usually isnt the guy swingin a 30 lb saw w a 24 in bar around a 5 in hemlock tree that you have to cut 30 limbs off to get into
The train of thought is that if the girdled trees die off slowly, and the crowns of the remaining trees keep up with growing into the new space, you will again have filtered sunlight. This is what needs to happen for maintaining clean boles in higher valued trees. Cut too much around a nice 15 inch white oak and the quality actually degrades when it starts producing epicormic branches.
girdling, is done here mostly on paper birch... ppl taking the bark for crafts and such makeing it dangerious for anyone working in the woods!! i would not perform this act as it is destructive to many other living species. not much differant then spikeing a tree!!!!!!
