Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Bd ft ? in a stickered pile  (Read 1892 times)
Offline alanh
« on: December 09, 2009, 06:50:19 am »
After catching the sawmill bug after using a friends  Woodmizer 15 on various small projects  I couldn`t resist cutting down a bunch of trees to make myself a large project. (See "air drying black locost" in processing) I was aware tha the month of Sundays it would take with the 15 wasn`t feasible so I hired a sawyer with a 40. I think everything went great, he charged by the hour and only stopped to eat a sammich. I was loader, off loader, and all around mill "byotch" which was fun, he certainly kept me moving. We got 25 logs done the first day and 33 the second, he is coming back next week to do another 10 locust and some hemlock. I stickered one days worth and was curious about the bd ft. The boards are random width and lengths are  8' to 12', stickers are 1" Is there a way to guesstimate the pile or do I need to figure each board?
Offline Chuck White
  • Sawing Mobile since 2005
Re: Bd ft ? in a stickered pile
« Reply #1 on: December 09, 2009, 07:05:50 am »
Welcome to the Forestry Forum and the world of sawmilling!
1. Imagine the stack of lumber as one solid piece of wood.
2. Board footage is figured by TxWxL.
3. In this case, first subtract the height (which would be your thickness) of the stickers, then do the math!
Hope this helps you out!
Chuck
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: December 09, 2009, 07:07:48 am »
Measure the width of a layer in inches,  divide by 12 to get feet and fraction of feet,  then multiply by the length in feet to get the board feet in a layer.  Then just count the layers and multiply.  It may be a little high due to gaps, round downs in width, etc.  But it’ll be close enough for horseshoes and hand grenades.
Sawing since '94
Offline bandmiller2
« Reply #3 on: December 09, 2009, 07:16:13 am »
Alan,we always use 4' long stickers and therfore 4' wide stacks seperate the different legnths 8',10' est.Just multiply 4x legnth x number of tiers for one inch boards.Frank C.
Offline moonhill
« Reply #4 on: December 09, 2009, 07:18:39 am »
Here is another version.   If the pile is 4' wide you can average it and call it 36" wide due to the gaps.  36 board feet per layer, that is in a 12 foot long pile.  If the pile was 16' you would do 36x16÷12= board footage for the layer.  For quick calc's I often will call each layer 50 board feet on a 12' pile, I need a good 20 layers for 1,000 BF, taken culls and such in to account and when I get it to the work site I have enough I hope.
Tim
Online ladylake
« Reply #5 on: December 09, 2009, 09:00:00 am »
  Don't forget to use  1.25  for the thickness if you have it sawed at 5/4,  1.25  x width of each row x length in inches  divided by 144 will give you the bf for each row. Now that you have us curious let us know the total.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline alanh
« Reply #6 on: December 09, 2009, 10:27:55 am »
Thanks guys, I`ll do some measuring  and math after I get home tonite.
Offline moonhill
« Reply #7 on: December 09, 2009, 12:08:40 pm »
I stay in feet for the length, that way you don't have to convert inches and feet.
Tim
Offline Bibbyman
    • Warden Sawmill
« Reply #8 on: December 09, 2009, 03:55:54 pm »
P.S.  We target 650 bf in a bundle when we're sawing flooring lumber.  Mary used a lumber crayon to mark how many layers of what length board makes a bundle.  That works for us as saw logs in batches by length and thus the bundle normally all of the same length boards.  We also make our bundles 42” wide as that is the width that two would fit nice across our truck bed.
But anyway,  if you’re going to do the math,  just make a table of what would be in a layer and kept it someplace handy – like write it on the wall in the sawshed.
Sawing since '94
Offline woodmills1
  • the truth shall set you free
« Reply #9 on: December 09, 2009, 04:25:20 pm »
I usually end up with around 3 foot of width of actual wood in a stack using 4 foot stickers give or take an inch or so
make it real easy by using just feet
8 ft  4/4 boards 3x8=24  call it 25 so 4 layers to the hundred
        5/4 is 1/4 more so 24 and 6 gives 30 per layer
12 ft 4/4     3x12= 36 per layer
I do this when cutting for others or to estimate a stack, but for myself I tally every board
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline alanh
« Reply #10 on: December 10, 2009, 08:55:27 am »
O.K.  Heres what I got, maybe you guys can tell me if I`m close. The boards are 1 3/8 thick,  have  two piles from Day 1 that are 5ft wide, average 12 ft long and there are 9 rows of boards. we also cut 8- 2X8X 12 that day and a couple 4X4`s. Am I close in figuring between 1400-1500 bd ft? Day 2 is still piled on the trailer and is noticably larger.
Online ladylake
« Reply #11 on: December 10, 2009, 10:39:45 am »
 That would be 1645 bf.   Steve
Offline garyfg
« Reply #12 on: December 10, 2009, 10:51:17 am »
Google board feet calculator and put in numbers and it will find the bft. You can't use 3/8. You have to use 1/4 segements. At 1.5 thick I came up with 1780
Offline woodmills1
« Reply #13 on: December 10, 2009, 11:18:09 am »
5 by 12 gives 60 so a quarter more for 5/4 boards is 75
75 x 9= 675
8 2x8x12 =128
each 4x4 x12 is 16 ft
I don't think he meant eight layers of 2by
Offline garyfg
« Reply #14 on: December 10, 2009, 11:27:29 am »
 He said there were two stacks of the 1 3/8.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #15 on: December 10, 2009, 04:51:16 pm »
Holy smokes ..... youse guys sure like to do feet and inches math...... too *DanG cornfoozing fer this guy....
If you do it all in inches, then all you have to do is calc the size of the pile, subtract the size of the stickers and divide by 144.....
So for example ....
pile = 120" long x 36" wide x 72" high = 311040 cubic inches
stickers = 35 rows at 1" thick = 120" x 36" x 35 rows = 151200 cubic inches
whole pile - stickers = 311040 - 151200 = 159840 cubic inches of wood
cubic inches / 144 = board feet ::: 159840 / 144 = 1110 board feet
Then do a rough guess of the wasted space in each row - if it's 20%, then 1110 - 20% = 888 board feet
cheers
John
Online ladylake
« Reply #16 on: December 10, 2009, 05:29:47 pm »
 One guy figures 5/4, one 6/4. I figured what it was.  I think he has 18 layers of 1-3/8..   Steve
Offline alanh
« Reply #17 on: December 10, 2009, 05:49:55 pm »
Yep, 2  piles, 18 layers of 1 3/8. Thanks for the help, We had some low yield logs and a couple that he sawed into, flipped, sawed, flipped, sawed and looked at me and said  "There`s nothing here"  It seemed the bigger base logs he had to work at for good boards but the smaller ones were solid. I can see the point of you guys saying they are tough to get good size lumber from, fortunately I`m looking for is around 4" wide decking so I can get a lot of good from them.
Offline woodmills1
« Reply #18 on: December 10, 2009, 08:57:31 pm »
2 piles doubles to 1350 all the rest stays the same
so 1483 plus the 4 by didnt say how many.
Offline woodmills1
« Reply #19 on: December 10, 2009, 09:05:01 pm »
width in feet length in feet estimate makes it easy
sorry I missed the 2 piles but feet by feet is easy
I tally al my own cut by the board
I tally all my customer cut wood by the board
when and if someone says how much for that stack I will estimate based on feet
3 foot wide 12 foot long 12 layers
DO THE MATH
Saw Anywhere!
